Hi Phil, we had no space in the truck, although I did consider mounting them to the camper over the center rear window, right behind the cabin. I didn't see a way to rail mount them. The weight on the roof isn't bad, but I have no illusions about parking garages or other covered storage For us, mostly solo vehicle desert camping, these made more sense than a winch, there is rarely anything to winch to and a sand anchor is a lot of cost and weight.Wallowa said:Thought about buying 2 Maxtrax MKII....not starting a 2 vs 4 discussion at all...
but if I do I hope to either put them behind the trk seat [easy to access, no 15 extra lbs on roof to lift] or mount them directly to the FWC YakRak rails..need to not increase the height of our Hawk above the solar panel; we only have 3/4" clearance entering the our shop where we store the Tundra/Hawk..
Not cheap $329.99 for two on Amazon.
But like our winch; you don't need them until you do!
Phil
gaylon said:Hi Phil, we had no space in the truck, although I did consider mounting them to the camper over the center rear window, right behind the cabin. I didn't see a way to rail mount them. The weight on the roof isn't bad, but I have no illusions about parking garages or other covered storage For us, mostly solo vehicle desert camping, these made more sense than a winch, there is rarely anything to winch to and a sand anchor is a lot of cost and weight.
Thanks! Our two 75# dogs take up most of the back seat area.Wallowa said:Makes sense....and I have a thing for not attaching anything that requires drilling into my Hawk or adding weight outboard...want it buttoned up tight!
Our Access cab with back seats removed has given us a lot of room inside...but that just adds up to more stuff and weight...
4 tracks in the desert is a no-brainer...and we also solo in BFE....cool, have fun.
Phil
I did the same except with square 1” bars. And ran the racks closer together and the traxx sideways. It makes it a lot easier to load and unload, I can stand in the door and do it and I’m not tall. Unless you are using the rack for something else have you tried that?gaylon said:Used Axia Alloy tube mounts and Maxtrax locking pins.
