I have been having problems for some time with the Atwood model 8516 furnace in my ATC Panther. It would light, run for one or two cycles and then not relight. I thought I would pass this repair information on to anyone who might be having a similar problem.
I finally traced the problem to the air flow switch (sail switch)located in the fan shroud. It would stick in the open position after the fan shut down and not allow the furnace to relight. The fix was to remove the front half of the fan shroud and replace the switch. Not too big of a job although it requires removing the igniter board to allow the shroud to be pulled out of the furnace.
On inspection I could see a mark on the fan shroud where the switch lever was rubbing and bent the switch lever slightly so there was more clearance.
So far so good, seems to work ok, it will remain to be seen if it works in very cold weather.
Dsrtrat
Dsrtrat
