DrJ
I recently replaced my battery set with 2 new (quite heavy) Sear's Diehard Platinum Group 31M batteries.
As I trial, I kept my 2 way compressor fridge and some lights running off battery for 2 days. My batteries were down to a charge of 12.2 Volts and it was time to recharge.
I hooked up the camper to 120 volt power to charge with the IOTA (with it's 4 stage smart charger) and could not get the volts above 13.0. Even after several hours - no increase in volts about 13.0. Strange.
Then I unhooked it and let the solar panels go to work. Again with 220 Watts and MPPT charge controller, I could only get 13.0 volts. It had 9.8 amps at 13.0 volts but would not increase the voltage.
Handy Bob would not be impressed.
Is this normal behavior for newer AGM batteries?
Anyone else had this problem?
I doubt my batteries would ever reach a full charge this way.
I called my battery guy who thought the batteries just were too full for a bulk charge.
Not sure how that could be with the 110 litter Waeco fridge running at 4 amps at probably 80% of the day.
It was 95 degrees outside too.
I can't imagine that I had not used at least 50 amp hours and probably much more.
The Sears guy who sold me the batteries has told me that I have to purchase the special Sears Diehard charger to successfully charge them. I can't imagine that is necessary. If so, they are definitely going back.
Do I have a problem with my batteries or is this just normal for new AGM?
