110V Charging question
xrisx
Oct 28, 2014
10
British Columbia, Canada
Hi All,
I just recently picked up our 2015 Hawk Silver Spur and have a question regarding charging the AGM battery while connected to 110V power. Will the battery charge with only the 30A breaker ON or does the 15A Breaker (Converter) have to be on too? I want the battery to charge with minimal or no draw, such as the CO detector, etc. Thanks
I have to ask why are you worried about the position of the breakers other than on? If all the appliances are off, the only thing drawing power is the CO2 detector. If you want to make sure there's minimal load why not just push in the master switch?
Thanks for the responses. It does have the IOTA IQ4. Kilroy, my thoughts are basically what your response was. I have always used a battery tender for winter storage, just seeing what other people are doing with the new IOTA IQ4. Looking forward to using it in about a month or so, surf trip to Tofino!
xrisx said:
Hi All,
In order for the battery to receive a charge, the DC switch, (the one that is a plunger) must be pulled out (on) in order for the battery to receive the charge from the IOTA. Pushing it in will disconnect the battery from the main fuse buss thus rendering no charge current to be sent to the battery.
I read all of the manuals, I just wanted to know if the battery would charge on 110V power when only the 30A breaker is on along with the master DC switch.
Both the main 30 amp breaker and 15 amp converter breaker along with the main DC switch must be on.
Great thread. I turn the power completely off when I put the camper in storage. Every couple of weeks I check the Zamp controller and after nearly 2 months I'm still at 12.5amps for the 2 batteries. All I have to do is pull the tarp back for a day to get solar input and I'm back up to 13.3. I'm weighing on getting a portable solar pannel so I don't have to touch the tarp, just plug it in for the day. jd
Learned this one the hard way. Ran out of enough juice to power up the heater. Was a cold morning....
Latest posts
