A different kind of leak problem
Tom n N
Nov 11, 2022
55
Los Osos, CA
As this is my first post I guess I’ll start with a brief introduction
I have a 2003 Eagle shell that I bought basically unused in 2004, mounted to a 93 Toyota 4x4 that I’ve had since new. My wife and I use it to explore remote corners of the western US. I really like the small size of this setup as I’m able to take it on tight rough trails where no sane person would normally take a camper. In all these years both the truck and camper have exceeded all my expectations and I will continue to repair rather than replace either one.
I’ve followed this forum for years now and even tried signing up once (apparently not taking new members at the time and never tried again). Anyway though I’ve found lots of info on leaks, have never heard mention of my particular problem.
When driving in hard rain at hi way speeds I get a leak at both rear corners that I never remember getting in the past. Always thought it was roof screws or vent, but on closer inspection it looks like the water is coming in through the soft side windows. This had me confused as not only are the inside flaps in place, but I also have the older style windows with the storm flaps on the outside. Only problem I can find is there is a slight bow in the top between the front and rear hold down latches that maybe let’s water into the folded sides. Would maybe adding another latch on each side help suck it back down flat to seal better? I’m open to any and all suggestions.
Thanks
Tom
Welcome to the cult Tom.
First there is a natural "bow" to the roof,it's the way they are designed and built.
Are the latches pulling the roof down tight enough?
Maybe adjust the screw part of the latch tighter,to pull the roof tighter.
Maybe post a photo of the roof area where you think the leak is coming from.
Not sure what you mean by a "bow". Could the roof have been sprung somehow?
Your in the right place for help.We have a great assortment of info members.
Have you checked for leaks on the driveway? I find having a person inside and another outside with a hose can help with locating leaks. Have you changed anything, assuming it didn't leak before? I had leaks in my windows with the same design as yours, but it leaked all the time when the top was up. Fixed that!
Another possibility is that the water is getting in elsewhere and just showing up in those places, since the water could get in a screw hole and travel down the 1" tubing for quite some distance.
Tom n N said:
...When driving in hard rain at hi way speeds I get a leak at both rear corners that I never remember getting in the past. Always thought it was roof screws or vent, but on closer inspection it looks like the water is coming in through the soft side windows. This had me confused as not only are the inside flaps in place, but I also have the older style windows with the storm flaps on the outside. ...
Thanks
Tom
First question where about on the "both rear corners"? Inside bottom or top of the camper? I'm not sure where exactly you are talking about a Picture pointing to where it is leaking is always helpful.
On your camper since you said it is having the issue at highway speed in hard rain... There is on the roof edge you have two roof vents with a cap open at the bottom. With the design of the air flow up from the windshield, water could be entering these two vents. Inside is a tube where the water might be traveling to the back of the camper and finding it's way out where you see the water on exit.
As far as the siding material leaking in... After you drive in hard rain, popping up is the side liner coated with water?
Do you still have the small side wall storage cabinets inside the camper ?
Or have they been removed ?
(see attached pic)
There should be one on each side wall, in the rear of the camper.
I used to try and "delete" those cabinets on new camper orders back in those days, and the production department wanted them in there.
They used to tell me that the small cabinets helped the soft-sides (pop-up liner) to stay "up", and not droop down in those rear corners. So water would not pool in there and leak through the velcro on the window.
Just a thought.
Thanks all for the replies. I finally figured out how to post some pictures (I think), so hopefully will make things clearer.
This is the gap I was talking about between the latches. Not sure if it shows, but definitely does not seem to seal as tight as at the latches due to distortion.
These are the areas on the inside where I'm getting water. It's worse on the passenger side. There is water in the windows, and also behind the windows as shown, but only at or below the crease. No water on the upper part of the side, or anywhere on the ceiling, so not a roof issue. In the past we used to take the camper off between trips, and most of the time it's used in the desert, so rain was not a problem. Lately though, drove it through some pretty good storms and that's when I noticed leak.
Any ideas?
Thanks,
Tom
Tom, after looking at your photos, I think Stan has identified the source of your leak. Water is getting up into the folded vinyl, then seeping through the Velcro. I’m not certain what the fix will be (reach out to Stan), but one thing I’d check is turnbuckle adjustment. If the turnbuckles have loosened over time, they may be allowing more water up into the folded area, contributing to your leak.
I would also check with Stan about FWC’s recommendation for proper turnbuckle adjustment.
I had a leak coming in through the front windows when driving in the rain. Found the front weather seal around the front of the camper had collapsed from being compressed over the years and wasn't sealing completely when the top was down. The collapsed section of the weather seal is hollow so i fished a length of 3/16 or 1/4" vacumm line into the hollow to return it to the original form. Has not leaked since. I snaked some welding wire through first and formed a tiny hook on one end, hooked and taped it to the vacumm line, then lubed the vacumm line with Dawn dish soap as I fed into the hollow section. Easier if you have two people when pulling.
Are those two spots where the lift panels rub, is there a hole?
Check to see if your inner clear window has shrunk and around edges are not sealing out the water.
Pop up and use water hose and hose down windows a have someone inside looking for water leak paths.
+1 to this. I had to make interesting mods to the windows to get them not to leak in the rain. Check here in my PUMA build thread https://www.wanderthewest.com/forum/topic/18289-vics-new-2012-puma-build/?p=235078
Well you all have given me a lot to think about
Lots of great info from Vic. Although I think he’s talking about leaks when the top is up (maybe I misunderstood) I’m still going to try the ‘glue and sew’ solution to prevent other problems I never thought of.
There are definitely no holes in the vinyl, and my latches are tight enough. In fact I think they may have been too tight in the past, resulting in some distortion. Since ours is a Shell model, we typically leave the bed pulled out and all bedding still on it. Even though we use a deflatable mattress, my dear wife can sometimes get carried away loading it up with pillows and blankets. ( if she’s willing to join me for cold weather camping, I’m not going to complain). This can result in quite a bow and may have tweaked it. I still think this may be part of the problem.
Also going to investigate the top seal, and Beach’s clever solution if possible on my year model. Sounds like something definitely worth looking into
Finally, never really paid attention to the seal of the clear plastic windows. I know when it’s cold out they don’t seem to lay very flat. Not sure what to do about that.
Going to head down to the SoCal 4WC rally in a couple weeks. All our trips are usually remote and solo, so will be interesting to see what others have done with their rigs and get some ideas. Maybe talk to others with this problem.
Thanks again for all the help
Tom
Tom
Tom, yeah, I was talking about top up. Ours didn't like with the top down. Still worth looking at though.
Latest posts
