The contest entry button (and many other features of the site) may not work correctly in older browsers. If you enter a contest, you should be able to see those entries as negative points in your points log. Points are recalculated every night so you need to check the day after you enter. If you do not see a -10 point line in the log for each entry you made to the contest, you are not entered!
Feel free to pm me if you are having trouble.
And again, if you are using IE6 you can assume that nothing on this site is going to work correctly as that browser is hopelessly out of date.
