A Reflectix Experiment
ski3pin
Belay On
Site Team
RV LIFE Pro
Jun 30, 2009
15,638
Sierra Nevada Range
During cold weather camping we have noticed quite a bit of condensation/moisture where our sleeping pad meets the cabover board. We are sure to pull out our pads and dry them after trips. Borrowing from others ideas for uses of the reflectix material, I joined two 2' wide pieces and then cut to shape to fit in the cabover. The sleeping pad will then rest on top of this. I will report on what improvement we find and also how the materials holds up with our body weight.
Sounds like a good idea, ski3pin.
I haven't noticed any condensation on my camper sleeping cushions...but that's probably because I haven't looked.
About a year ago I added a piece 1/2" closed-cell foam under my stock bed cushions/pads -- not for insulation but for more padding...but I suppose that is doing the same thing as the Reflectix would do -- warding off condensation.
The 2-inch mattress pieces that came with my FWC have fabric on the top and waterproof vinyl on the bottom. These came standard on my Eagle in 2008. Is this unusual, or do others have this as well?
Mine, too -- in my 2005 FWC Hawk.
I have a 2011 eagle. I noticed condensation after a trip this fall. I think, though far from certain, 2 layers would be better in the sense that, keeping cold air from hot, reduces condensation. Reflecting the cold out(down)and reflecting the warmth in(up) would be best. I will try this this spring (we live in New England) and will report back.
Never heard of this feature before. The ones on my 2003 are all fabric.
I have been thinking about the best way to insulate the cabover. Came to the conclusion that this was at least the best place to start. Will be interested in how it works for you.
Where are you getting your Reflectix from?
Our 08 Hawk has 4" factory pad with vinyl on the bottom, which acts as a vapor barrier. We haven't noticed condensation, but maybe we're not looking hard enough :sneaky:
Here's some results after four nights in Death Valley. Overall we are pleased and will continue to use this. It did keep the cabover sleeping area warmer. However, it did nothing to lessen the condensation/moisture under our sleeping pad we find in the morning. Moisture was at both interfaces - pad/reflectix and reflectix/bottom cabover board. It is easy to just wipe up on the hard surfaces and dry the towel outside when you can. It is harder to dry the mattress covers. We pull them out when we have direct sun. Since they are dark colored, getting rid of the dampness only takes a few minutes. Vinyl bottomed pad covers sound like a good idea.
Mine three in a 08 Eagle.
We tried the reflex a while back but did not attach it to the bottom so it moved around on us some. I thought it was more comfortable and warmer. Not sure about condensation.
I have been using Reflectix under the cabover mattress for 3 years. I did it for warmth and would say that it did improve what I felt was a drafty sleeping area. I never had a problem with moisture before or after. With the vinyl bottom mattress would you not still have a moisture issue, it wold just be easier to dry?
My wife and I were just this weekend talking about the condensation that we have noticed in the sleeping area of our Hawk. It is only around the lower couple of inches of the soft side near our heads and strangely on the wood molding on the ceiling from our heads to midway across the width of the entire ceiling. I presume this due to our breathing. We have the waterproof lining on the bottom of our cushions also and have not noticed moisture there, but then again have not looked for it.
We have replaced our cushions with a memory foam mattress and I am curious to see if it gets moist.
We tried the Reflectix under the bed, works ok. Condensation goes from wet to just damp. A 1/2 inch solid foam sheet works much better though. We have the short cab-over on our Granby.With the bed pulled out there is a 1/2 inch difference in height from front to back.The solid foam levels things out and makes it easy to lift the cushions over each other when we slide the bed back for more room in the day time. The condensation doesn't go away with the solid foam in real cold temps(under 15 degrees), but way better than without! That's with the stock 2 inch cushions though, we haven't been out in the real cold since we added another 2 inch piece of foam under each cushion. We now have to leave the bed pulled out when we travel, but it's way more comfortable sleeping now. We'll give it a good test over Christmas. Going to Williams, AZ and to the Grand Canyon. Ought to be cold and snowy and "Christmas'y"
John
Those who are having condensation issues, you have a vent over the bed area? If you do, do you leave it open at all?
For us, we have only been out a few times but haven't noticed any issues but we do leave the vent open an 1" or 2. It also hasn't been colder than the low 50's to high 40's so that might have something to do with it.
Just curious.
I'm curious...next time you camp in cold conditions check inside the zipper and feel if it's wet inside the foam at the vinyl side. I was thinking of wrapping our bottom foam piece in plastic, but then thought the pastic might just hold the moisture and keep it from drying out in the morning.
Thanks
John
Just curious.
I have 2 vents, one over the bed and one over the kitchen area. I always crack both open, years of camping in a tent taught me to always vent for the condenstation.
My wife and I have been wondering about the polar pack and condensation issue, if it would eliminate the moisture on the soft sides. We have noticed in the last few months that the camper has been draughty up by the soft sides more than during the summer. I'm sure that is one of the reasons that FWC came up with polar pack.
Just curious.
We usually don't start getting condensation till it get's below 50 degrees at night, unless it's really humid and near the dew point. The problem is a cold surface against a warm one. More insulation means less condensation. We used to have a lot of condensation (hell call it what it is...lots of dripping water) on the vinyl. When we started using Reflectix (a poor man's artic pac) we no longer had the water trouble. Never on the inside, but maybe just a hint of water between the vinyl and Reflectix near our heads at night. We still had really damp cushions underneath the bed in the morning. I put a solid foam sheet under the front(my side) of the bed and found the damp greatly reduced. Can't wait to try things again now that we have 4 inches of cushion instead of 2. About the same time as the solid foam we started using our Wave6 heater. This meant we had to provide good ventilation to insure the O2 being used was replaced. We open the turnbuckle door beneath the fridge a couple inches and open the window near our heads. This also helps huge with the moisture build up inside.
John
