A stupid Question
1tonpaulie
Contributors
Nov 26, 2009
142
Johnsburg, Illinois
I have a 2010 Grandby on a Ford truck. The cable that connects the camper to the truck has three wires that hook to one battery and a ground.
My question is how do the marker light hook up to the truck. I don't get it. This must be magical.
Thanks for your help
Paulie
Automobile 12v systems don't 'really' have a seperate ground, they have Battery (+) and Battery (-), so I am guessing you have battery (+), battery (-) and the running lights (+) on the 3 wires. :D
The wires are Battery positive and Battery negative (aka ground - it can be connected to the chassis most anywhere but best to run direct to the engine ground post that the battery connects to) and marker light. The marker light can be tied into the trailer lights wiring. The trailer light wire bundle can be found under the chassis and tapped into, or you can get it at near the fuse box or at the connector itself at the rear bumper. One will be for trailer running lights, others for left, right turn, brake, and reverse (backup). May have others for charging power. Thre are other ways to get this as well, such as run a new power relay's coil off any ignition switched circuit.
Search for trailer connector (4, 5, 7+ pin RV connector) that matches your plug or you can look in the Ford manuals. You can find what pin does what function. In the case of my RAM I found the Dodge body builders guide and it has the cable routing plan so I knew where to tap into the bundle and what wire color to look for, under the chassis near my camper connector for a short run.
Ok I understand better now. The thing that through me was the white wire to positive and the black wire to negative.
Thanks for your help!!!!!
Paulie
My 2009 FWC has 3 wires (black, white, green) in the cable running from the camper to the socket in the truck bed. The white wire is battery (+), the black wire is battery (-), and the green wire runs to the camper running lights.
