Steve Scearce
Contributors
My wife and I headed to Chaco Canyon last weekend and I noticed the driver's side of the bed was sagging a little at a fuel stop, so I added some pressure to the driver's side airbag and we continued on our way. Long story short, what I didn't notice is that the bottom bracket of the airbag (AirLift) that is U-bolted to the leaf springs had worked loose and moved forward about 5 inches. Yesterday I took the camper off and jacked up the frame to let the springs relax. I deflated the airbag down to 15 lbs and loosened the u-bolt nuts and was able to slide it back to it's proper location. I took my truck to my mechanic today and he further tightened the nuts on both u-bolts. There was a minor gouge in the airbag, but not all the way through. Close call. Anyhow, my mechanic speculated that bracket moved forward on a hard, fast turn during some sway.
Anyone else ever have this problem? I'm thinking sway bars are now on my shopping list. I'm definitely going to check the u-bolt nuts regularly.
