And the wilderness gets a little less wild
Cayuse
Apr 18, 2014
771
Mesa, AZ
They've paved more of the Burr Trail, apparently rushing into it without giving time for an appeals process so now there are lawsuits...
Salt Lake Trib Article Here
Really don't know why they's want to do that other than someone in county government must own interest in a paving company. Not like there is going to be commercial traffic between Boulder and Bullfrog.
Yep, this sux. They probably figured it'd be simpler to just ask for forgiveness after the fact. Sadly, there's a lot of that mentality going around these days, and it doesn't bode well for the future.
Rico.
I guess they did it for a number of reasons, but chip seal isn't really paving, especially if it wasn't applied to an already paved/asphalt road. Chip seal is a great way to reduce annual maintenace costs, increase driver safety and and at minimal cost. It'd be interesting to know what was actually done, because if they just applied a chip seal, it sounds like this story is much ado about nothing.
We'll have to agree to disagree on this. Every definition that I've found considers chipseal a form of pavement. Like I said, the wilderness is a bit less wild, are they going to chipseal the road to Tuweep next? Cottonwood Canyon? House Rock Valley? Their is nothing wrong with having unimproved dirt roads for people to travel, there are plenty of hard surfaces for others to travel on.
When you say there is nothing wrong with having unimproved dirt roads to travel, it depends on who you ask and what you ask of them. If the BLM is responsible, or any other organization or entity, for maintenance then there is something wrong with unimproved dirt roads. They are very expensive to maintain, to monitor for vehicle travel/traffic and for recovery costs and damage claims. I managed an area with dirt roads and it was very costly and we regularly had complaint and claims for vehicle damage.
The governing body for the area I managed looked at the cost of maintenance over time versus adding a chip seal to the dirt surface and realized very quickly that dirt roads are like the Jeeps that travel them, a hole that you can never fill, regardless of the money you pour into them. Add a chip seal and you can extend the life, lower the cost and provide a level of service an unimproved dirt road cannot. So, there can be something wrong with them, based on the expectation of the driver and expectation of the tax payer.
Not saying a chip seal was the right decision, just that there are valid reasons, agreed with or not, for adding chips. Oh, and chip seal is usually applied to an already asphalted road, to extend the life and add safety. It's usually not added to a dirt surface, although it was in the area I managed. We specifically added it to a dirt surface and in my mind that's not paving the surface; although, I can understand the argument that others would make that it is. In my mind it is more of a binder and adding additional rock, but that's my "opinion."
Ace, I work for a local government and know that we only use chip seal on already paved roads to extend the life of the road as you say. But I don't work on those projects, so have a question. It seems a chip seal over a dirt road would be extremely thin and unable to stand up to much traffic without the asphalt base. I would think it would just be broken up into oily gravel itself in a very short period defeating the purpose. Is this not the case?
Yep-it's not so much the "What" as it is the ":How" that is the problem! They invent their own rules and short shift the EIS/Ea process as SOP. We just got to keep writing those letters and attending those public meetings.
Smoke
Smoke
Smoke, thanks for getting back to the point of the lawsuit.
There is a road in my neighborhood that I walk daily to keep my FitBit happy. The powers that be decided to revert from asphalt to gravel to reduce maintenance.
To that end, they removed most of the pavement and prepared a gravel surface. A resident with some political clout complained and got the county to chip seal the gravel surface. The chip seal surface is not as durable as the remaining section of asphalt but it isn’t muddy, dusty or washboardy. No rocks thrown into windshield.
I can understand the frustration of those responsible for the road upkeep to balance rural road budgets with tourist complaints of road surfaces and preservation of pristine environments demanded by non resident vocal entities. They have a difficult task. Cut them some slack. :)
It is (very) thin. That's why (in my opinion) I wouldn't consider it a paved surface. It is a thin layer of liquid binder (liquid asphalt) with very small "chips" (which you probably already know :) ); however, even that thin layer can last ten years or so. It will certainly depend on the base (rock) as all roads do, storm water management (nothing kills a road like water) and contour and traffic patterns. The chip seal creates a harder surface than the gravel road, and that greatly reduces water intrusion (increased life, reduced maintenance) and increases traction (increased safety and reduced maintenance). We've had really good luck with gravel roads that are well maintained. We added rock to the base and chip sealed them to reduce our annual costs greatly.
I live on a road that was gravel and was chip sealed eleven years ago. The road is still in good condition and is much superior to what existed before. It gets quite a bit of traffic as there are about 40 homes located just above my place. Locals have been surprised (pleasantly) over how the road has turned out. The county does another increment of chip seal annually and usually it is over gravel surfaced roads.
I just read this and I'm a little confused. It sounds like Burr trail/rd was all paved/sealed except for a 7 mile stretch. Was that stretch truly wild or was it just not paved. By the looks of that picture it's 30' wide but maybe they did grade work too. My property here is off a dirt road that get an occasional chip seal. You can tell when it needs resealing because huge clouds of dust get kicked up every time a car passes at 60 mph or so. Depending on the wind direction anything within about 1/4 mile at least gets covered with dust that was road five minutes earlier. I understand the 4WD guys want their space away from the 2WD folks but huge clouds of dust are hardly 'wild' when they are kicked up by some guy in a Raptor checking their suspension travel limits. On my road after the seal it looks black but within a fairly short time it's dirt colored again just way less dusty.
