takesiteasy
I stopped at the truck scale at the start of my last trip. I was curious. My camper is a modified ATC shell model- shorter and narrower than a normal Bobcat. It has a furnace and propane tank and two small storage boxes built out of plywood (you can see the details here). I have a Dometic CF50 fridge bolted in under the cab-forward window. I have a 10 gal. Frontrunner footwell water tank that was empty. I was carrying 2 gallons of water in the camper. At the time of weighing, the camper was fully loaded with 200 lbs of food, gear and clothing, the dog was in the truck but no people. The gas tank was 5 gallons shy of full. I have D-rated tires that I figure add about 50 pounds total over OEM tires and an extra battery that adds another 50 lbs.
Here are the results (sorry for the poor formatting- couldn't figure out how to do tabs):
Axle-- Actual-- Toyota Spec Limit-- Difference
Front Axle-- 2560 lbs-- GAWR 2755-- 195 under limit
Rear Axle-- 2920-- GAWR 3110-- 190 under
Total-- 5480-- GVWR 5350*-- 130 over
*(not sure why the GVWR is 515 lbs less than the total GAWR for the two axles).
I figure adding two people (350 lbs ), 8 more gallons of water (64 lbs) and 5 gallons of gas (30 lbs) would put me at an additional 444 lbs for a total fully loaded weight of 5924 lbs (ignoring the two empty fuel cans hanging on the back). This is 574 lbs over the GVWR, or 10.7% high. I was surprised since my camper is bare bones. We carry pretty minimal gear. I don't know how I would get the weight down to the GVWR. At least we are close to the individual axle ratings. The truck handles fine and doesn't seem overloaded. There is still capacity in the stock suspension with the TSB rear springs. Braking, acceleration and cornering are all good.
I am curious about others' experiences and observations.
