As a noob camper owner, I'm on the steep learning curve of figuring out the charging system. I bought and installed a Trimetric monitor a couple of months ago, which has been very helpful.
Today I offloaded the camper so that I could use the truck to haul some materials. When I checked the Trimetric after unloading, it showed that something was drawing 0.5 A from the house battery. Disconnecting all of the 12V loads by using the 12V master switch didn't change that.
The only thing that I could think of that might be draining the battery was the solenoid in the 1314a battery separator, and sure enough, it was warm to the touch. Felt just warm enough for about 6W of heating, so I'm pretty sure that's what's draining the battery.
It's been continuously draining the battery at 0.5 A for 4 hours now, and I guess it will keep going until the house battery drops to 12.4 V and the solenoid kicks out. Is there any way to stop this drain, other than disconnecting the battery?
Thanks for any suggestions!
- Rusty
- Rusty
