Montreat
I am sure this has probably been addressed under the electrical section but when I read it I get lost in the jargon. Can you swap a stock 4wc rig with 2 factory agm batteries to lithium without changing anything else? Just hook them up the same way.
If you want to go the 6volt route can you swap the 2 12volt agm for 2 6volts?
Thanks for your help.
