Bed ?
dennis 221
Oct 11, 2019
407
So I cleaned fwc an wanted to rotate bed. Two corners are rounded and two squared well i run into problems by rotating bed?
Yep you figured it out ;) They only fit one way because of the factory corner radius cuts. You can take the cushion out of the cover and flip the foam over slide it back in. Or extreme, take the foam out and cut radiuses on the square side and put those cuts on the factory radiuses and re insert the foam back into the cover. ;) ;) :)
FYI I have never done either of the two mentioned and never will, just thinking out of the box.....
