Squatch
I figure this may have been covered but I haven't seen it.
The gray paint on the plywood part of my Eagle needs a recoat. I'm thinking of using a DIY polyurethane bedliner to coat it. One of the ones with ground rubber crumb in it. Has anyone done this here?
When I redo the bed on the Moon truck I will use a DIY bedliner but one that is smoother without the rubber crumb. So I figure the stickiness of the rubber on the camper bottom will help keep it from moving in the bed and I won't need the extra weight of a rubber pad.
I'll probably use this product. I've used it before on my boat topsides. It's a water based marine product and holds up well.
http://www.tuffcoat.net/wordpress/marine-2/
This is what it looks like on my boat. Very UV resistant compared to most of these products.
