I have a Raven shell with a heater. The previous owner put in a marine board counters on the heater side, a marine board shelf on the window side and a Sterilite three drawer unit near the back in front of the window. After using it for a year, I think I can do better, so I am ripping everything out (hence the need for a paint match).
I plan on putting in a Corian counter with an undermount sink on the heater side and running gray water outside the camper with a Camco hose unit. We'll drain on the ground where we can and collect it with a hose where we can't. It's essentially replicating what Scout is doing in their new line. I'll do a door below the sink, and drawer(s) to the right.
On the opposite side, I plan on a 2 or 3 drawer unit in the back corner.
The question is, what to make it out of. I'm intrigued by expanded PVC due to the weight. I can paint it to match the walls now that I know the color. It will add a layer of protection to an otherwise softish material.
I want it to look intended, and not thrown together as much as possible.
Has anyone worked with expanded PVC? Pros? Cons? Alternatives?
Thanks!
Thanks!
