Can't Find Breaker 69 NCO
dkoug
Sep 18, 2012
54
Embarrassing but can not find main breaker in my 69 Alaskan.
Not in any cup boards near entrance door.
Not under sink or fridge or closest.
Any ideas, figure there must be one?
thanks
dkoug
in my 64 10' nco --- there was no fuse box or breaker or single fuze-- the only spot it could have been was in the outside plug box. that part was missing in mine.i just had a cluster of cut wires.those, i had to trace and test with a multimeter on the resistance setting . i finally figured where the important ones started and ended.(some changed colors somewhere behind the paneling)
wes
Guy's
Thanks as suggested by Buckwheat this afternoon I sent a message to Brian.
dkoug
Hello
Gave up on finding breaker/fuse for this 69 Alaskan. Changed the 110 volt male connector on the Alaskan to a modern one that will accept a female connector. Since could not find fuse/breaker plugged the 110 v from my garage and no fire. The one light of the 2 ceiling lights worked and the one 110 v duplex fired up my plug in radio.
Now I'm thinking that the 12 v system only is connected to the running lights, will have to get exterior female connectors repaired and find out. Or if I put 12 volt lights in place of the 110 v lights the 12 volt system will fire the 2 ceiling lights???
Any advice would be appreciated.
thanks
dkoug
Thanks to coloradocamper
He provided the location, same as 60 vintage Alaskan.
Above the rear door in a cute well make box.
dkoug
Latest posts
