Hey all,
New here, but been on expedition portal and figured I would come check out the scene over here and hopefully gain some insight from you guys.
I'm Graeme.
A little backstory before getting into the build...
About this time two years ago, I was working offshore oil in equatorial guinea and dating a girl back in Montana. I took the job because the schedule was awesome, and it satisfied some pretty considerable wanderlust. Worked in oil for about a while and I ended up quitting the job for a combination of ethical and relational reasons. After that, I decided to go back to school and also happened to get married. The wanderlust is still present, and before getting married I would have bought an expedition motorcycle to quell those urges, but now a truck makes a lot more sense.
Like most everyone here, I went through the whole process of wanting to build a lightweight popup camper on the back of a toyota phase before realizing that one ton diesels are cool too. I even bought a couple of older pickups to try to start that process. While I still dig the idea of an ultralight camper on the back of a tacoma, the small size and low payload capacity make the idea less appealing for long term trips.
So the next step up is obviously a giant, loud, stinky one ton diesel. The build will be a stressed skin aluminum cabin with a pass through into a crew cab truck. This project will not only be a means of travel for my wife and I, but it is also going to be a bit of a design portfolio piece. The multidisciplinary design aspect of these builds is really interesting to me, and I hope that it pans out as well in reality as it does in my head. So I want to build this thing out and then drive it to Ushaia and back.
Also I am going to school for my Masters in Mechanical Engineering, so this will probably be a good topic of discussion for job interviews... */end justification.
I trolled the sale section here and bought a relatively clean 01 f350. I didn't want to break the bank on a newer model truck, and I wanted to avoid emissions stuff, so the 7.3 seems to be a good choice. It's loud and stinky, but it is a solid platform.
So I flew to North Carolina, picked this up and drove it back to Bozeman by way of Feltz tire in Wisconsin.
Picked up 5 HMMWV wheels and tires, and put in an order for some aluminum wheel adapters to mount them to the truck. I debated stepping up to 20" Ricksons and some MPT 81's, but couldn't justify the cost. At 200/wheel & tire in brand new shape (Takeoff spares), a set of 5 is cheaper than 2 MPT81s.
And the result is a pretty factory look with no rub at full lock... Which is good because the stock turning radius is terrible to begin with.
Truck is pretty tall, but I think to maintain good breakover angles, such a long truck needs a bit of height. It is definitely geared tall, so I think I gonna swap to factory 4.30 or 4.10 axles, and maybe throw a Dana 60 under the front while I'm at it.
Next step is the flatbed delete and frame extension.
I'm Graeme.
![24273137583_21179435c1_z.jpg](/proxy.php?image=https%3A%2F%2Fc2.staticflickr.com%2F2%2F1526%2F24273137583_21179435c1_z.jpg&hash=a3331baacdab12f82f361362eb1e253d)
![24532745649_3838bc2c31_z.jpg](/proxy.php?image=https%3A%2F%2Fc2.staticflickr.com%2F2%2F1450%2F24532745649_3838bc2c31_z.jpg&hash=a5f7bee8f78aec855adc53de87b2d663)
![24873758546_785da94b6b_z.jpg](/proxy.php?image=https%3A%2F%2Fc2.staticflickr.com%2F2%2F1516%2F24873758546_785da94b6b_z.jpg&hash=db3ece1ce28f55c6c423ef10f7ec6d9b)
![24782435002_3c36e1ce06_z.jpg](/proxy.php?image=https%3A%2F%2Fc2.staticflickr.com%2F2%2F1697%2F24782435002_3c36e1ce06_z.jpg&hash=77d5167df2a2653599ab6e4f9cd3f2f8)
![24874065106_da0e6f2f07_z.jpg](/proxy.php?image=https%3A%2F%2Fc2.staticflickr.com%2F2%2F1534%2F24874065106_da0e6f2f07_z.jpg&hash=63036ba5c4376a1d372c74c8debe0481)
![24604587760_04481d142d_z.jpg](/proxy.php?image=https%3A%2F%2Fc2.staticflickr.com%2F2%2F1442%2F24604587760_04481d142d_z.jpg&hash=60c02945c894b40b3117de91231e3dec)
