do you lower tire pressure when you remove camper
campito
Jun 7, 2020
72
Bishop
I have E rated tires. I run 50/55 psi with camper on for highway miles. Should I lower pressure with camper off?
My only experience with E tires is with camper on, so don't know if I should continue with high pressures.
2005 Tundra.
IMO you need to lower the tire pressure without a load or
the tires will wear in the middle of the tread and not the whole tread.
Same for under inflation the tires will wear on the side of the tread more.
Also braking might be better with proper inflation for the rear axle. On our setup, all the camper load is on the rear axle.
