Eagle on Tacoma Help
Mar 9, 2017
25
Few items, I just picked up a used 2010 FWC Eagle for my double cab long box 2nd gen Taco.
1. Has anyone taken a hack saw to the front bumpers of their camper to shave them down an inch or two? The gap between the cab and the camper seems unnecessarily massive on mine.
2. Mounting it. I'm going to attempt to do my own install using angle iron or D rings and the factory bed mounting bolts. Anyone else gone the DIY route? How hard was it to remove the big hex bolts and install something?
3. Anyone store a bike inside their camper? Thought about installing a fork mount somewhere or wedging a 2x4 between the wheel well spots and mounting a through axle fork mount for my mountain bike.
4. Leg/jack removal? It appears most people remove the jacks and leave them at home. I will be on the road for 4 months and doubt I will be removing the camper from the truck. Doesn't seem like it's worth the hassle. I assume if I got a flat my factory jack could handle the extra weight to lift the truck with camper on?
Congrats on your new camper. I'll help with question 4. Yes leave the jacks at home. With a smaller truck, shave weight where you can. We were curious on how well the factory jack and equipment would work when needed with the addition of the camper. We practiced scenarios here at home - jacking and changing tires - and gained the confidence all would go well in the field.
Hello alijabosdotco
Congrats on the eagle, and the 4 month trip, don't forget to share with us home bodies. I'll take a stab a #1 call FWC, might be you could but I'd be willing to there is a reason the chose that thickness of a bump stop. You could probably find a thinner one online or from them if they give the green light.
Russ
I'm running another brand on a Frontier CC Long Box:
1. My bump stops are only 2 inches and work fine. Just make sure you have clearance on the front of your bed/windows etc.
3. We have put bikes inside, kinda a PITA. You want to get something or get in late and have to take the bikes out. If they are mountain bikes, they may be a mess and they you are putting all that dirt in your camper. We are putting together a swing away rear hitch rack.
4. Take em off, I already has the unfortunate experience of ripping one off when an off road puddle was deeper than I thought (I was able to repair, but still sucked). As Ski3pin said, just make sure you can change a tire. and don't forget, if you leave your tailgate on, you may not be able to access/lower your spare.
Enjoy the trip!
Thank you for the time and thoughtful responses.
The only reason why I want my bike inside is because I am going to be spending some time in places like Raleigh and Atlanta etc., and I'd rather have it out of sight from some opportunistic thief. Dangling a $3k bike infront of a meth head = stolen bike.
I removed the front bumpstops completely when Chris at Rocky Mountain Four Wheel campers and I installed it at his shop. We put just a 1/4" thick piece of rubber in front of the camper. Looks so much better with it mounted as far forward as possible plus it's best to have the weight as far forward as possible too. I keep mine mounted full time so yes the jacks are off and stay at home.The factory mounting hardware for the bed is good equipment, I'd just bite the bullet and buy it. I have upgraded my turnbuckles to 3/8" and believe I ended the breaking and loosening problem. Ron
Thats the one, they said it was coming to Mass if you did not buy it. Looks like a nice FWC. Did you get all that batter power? Enjoy.
I also prefer to travel with bikes inside my Eagle. I mounted cargo track each side of the cabin floor and then ran an 18" deep pc of plywood between the two sides with fork mounts screwed into the ply. I can securely carry jerry cans, hi-lift jack, and two bikes all mounted to the ply. More people room with just one bike of course. Straps run to the cargo track moveable rings secure the bike side to side.
Champer,
I am picking up my shell next week and also have thought about mounting my bikes(expensive) inside the shell. I am trying to envision your setup. Is there any way you could snap a couple picks? Thank you.
I'd love to see a photo too! Sounds interesting.
Here is a pic where you can see the rails on each side and the plywood spanning between with about .5" gap underneath - enough to slip the end of the mat under. There is a midspan support also. Box holds 3 strapped in jerry cans of water or gas. There is a specific cargo track attachment that has a threaded post which I used to hold the ply as it sits on the track. I swapped out turnbuckle doors for aluminum so rings could fit there otherwise doors were fine. The other bike mount goes over where the hi-lift is attached. Lashing down loads helps keep everything stable on dirt roads.
Yeah, I was going to go for something like that. I have a fridge in the middle where your jerry can box is and I'm a bit worried about pedals scratching things up but I guess with some care it can be done.
Latest posts
