Electrical problem
Casey's Daughter
Feb 27, 2022
1
73 NCO Alaskan. Everything has been working fine. All of the sudden no power to plug ins and 2 lights at front of camper. Light by stove still works. How can that be and what could be the cause? Breaker was not tripped.
I'm not sure but I would take each receptacle and light that isn't working off and examine it to make sure you didn't lose a connection. Possibly, one of your receptacles has gone bad. You don't have a GFI receptacle do you?
Lost my GFI in my ‘14. Caused all my 110s to be dead. Then lost some lights. Nothing tripped all fuses GTG. Pulled the breaker panel and found a loose wire and that fixed the lights. Replaced the GFI and the plugs started working again. After a weekend away came to find GFI blown again. Back to the drawing board on that.
