Exterior Lights
jdonovan
Aug 20, 2011
10
I have a 68 Alaskan Camper and I need help finding the factory teardrop marker lights and the round porch light. A couple of the marker lights are broken and the porch light is missing the lens cover...thanks in advance Joe
Is there a name or part number on the original porch light lens. Not have much luck finding one...thanks..Joe
Hi Joe, I am also looking at replacing my rear porch light cover. I am thinking I may just replace the entire light with a modern circle light with LEDs and a clear magnified lens. This way it matches the original, but has all advantages of modern convenience. I suggest checking eBay for the teardrops or vintage trailer supply, and also check eBay for the circle porch lens. When you do your Google searches, search for vintage Van or Truck dome lamp/lights.
If you find a match, let me know. Good hunting! Below are some links for you viewing.
Oz
http://shop.ebay.com/i.html?_nkw=teardrop+light+rv&_sacat=0&_odkw=teardrop+light&_osacat=0&_trksid=p3286.c0.m270.l1313
http://cgi.ebay.com/ebaymotors/Vintage-Chevrolet-Ford-Dodge-Van-Truck-Dome-Lights-USA-/170406049924?pt=Vintage_Car_Truck_Parts_Accessories&hash=item27acfdf884#ht_500wt_956
I looked for a lens, but ended up replacing the whole light with a Perko brand marine dome light. It wasn't cheap, but its good quality, made in the USA and pretty close to the original.
Tom
Like Mike said............
http://www.vintagetrailersupply.com/Teardrop_Light_p/vts-214.htm
I fought finding a replacement for the round as well and ended up with a rectangular 12v rv light...works
I bought the new teardrop lights. They are a good replacement, until I find the correct Reflecto-Lites. I also found a lens for the porch light. The lens has a lip in the inside, that I ended up cutting out with a utility knife. It did go on without doing this, but you could see the edges of the lens pucker out because of the high spots on the light base. My light base has 'Lo-Volt Inc" stamped in it. The base also has a hole in it like there was a screw/bolt that help secure the lens on. I was also thinking of drilling a couple of holes in the lens side so that the lens is secured better, still thinking of options. I don't want to replace the light only because the camper is in remarkable shape and I want to try and keep it original as much as I can. You can buy the lens at www.vintagecampers.com. The lens has "signal-stat 77-570" on it.
Nice! I will order mine tonight! Any other projects?
Oz
The original seal needs to be replaced. I understand the new stuff is Perelli. It looks like the original was made from cloth material. Does anyone know what this bracket(see picture) is for. It's located in the rear, near the tailgate. Also, its a tight squeeze getting the truck in the garage. Will have to work on that too....Joe
Its used to hold the top of the dutch door open.
JD...the door handle fits behind the bracket to hold the door open....
Don't let your door fly open in a wind....it will clip the bottom of that bracket off...and guess what???
They don't make them anymore, you've heard of the proverbial hens teeth :rolleyes:
I just found a replacement for my broken one the other day
FYI, this store has 5 of them for sale: http://vintagecampers.com/viewpart.php?partID=1868
Door Bumper and Hold Back
