Falcon Rebuild - Heater Options
Styx2015
Sep 3, 2020
17
Ok let’s talk heaters:
My wife and I are in the planning stages of a full rebuild on a 2002 Falcon. From the factory, it was optioned with an Atwood Hydroflame 16000 BTU forced air furnace. Why on earth was 16000BTU necessary? Total square footage is only about 52 square feet and total volume with our increased pop up height will be under 260 cubic feet. That many BTU’s would be enough for a mid sized travel trailer...
Anyways, we are thinking that heater technology and efficiency HAS to be better now than 18 years ago, so we are looking to use a new heating system. We will be living out of the camper for about 3 months at a time and seeing all weather conditions in varying regions and altitudes. We have settled on using a propane heater to keep the camper operating on a single fuel source along with our two burner stove. We aren’t keen on a diesel heater.
Right now we have three contenders.
1. Dometic DFSD16 forced air furnace. This is basically an updated version of our existing installation. 16k BTU
2. Camco Olympian Wave 3/6/8 catalytic heater. Still undecided on the size. 3k, 6k, and 8k BTU’s respectively.
3. Propex HS2000 blown air heater. 6483 BTU. Many vanlife folks have used these heaters successfully.
I know these three heaters have some slightly different operating principles with forced air vs catalytic. Obviously there are advantages and disadvantages to both. Can anyone provide some insight, advice, or real world experience with using these heaters? For those with factory heaters, are you happy with their performance, efficiency, and noise? Is the Propex better than factory? Are the Camco catalytics worth the sacrifice of no thermostat control as well as safety consideration and ventilation requirements?
Really just looking for some real world experience from those that have installed and used before. A cut sheet from the manufacturer only tells so much. Thank you in advance!
It will take some research to find the answers but make sure you are comparing like specifications.
As I understand it, the Olympian Wave heater BTU rating is energy put into the cabin air because the exhaust gases are dumped into the cabin, while the Dometic BTU rating is the energy consumed by the furnace. The 16 consumes16000 BTU’s of energy from propane but puts something like 12000 BTU’s into the cabin with the difference going out with the hot exhaust gas.
Haven’t seen anything on the Propex but it also dumps hot exhaust gases outside the cabin. However, you would need to see if they report net energy into the cabin or net energy consumed from the propane.
Without that data point, you may not comparing apples to apples.
Propex does provide this info. Heat input: 7165 BTU. Heat output: 6483 BTU. A bit of math shows that the Propex is therefore is about 90.5% efficient in its heat delivery. Power draw is 1.9A.
I was able to find input and output numbers for the dometic as well. Heat input: 16000 BTU. Heat output: 12,160 BTU. Efficiency of 76%. Power draw is 3.4A
The Olympian Wave heaters actually provide radiant heat. This serves to heat the objects in the cabin vs the air. Air heating would be convection heating. Since these heaters do not have thermostats and just a few settings (low, medium, high), we would run it in the evenings to warm up the camper, shut it off at night and burrow into our sleeping bags, then turn it back on in the mornings to take the chill out.
My thoughts between the Propex and Dometic are that the older campers must have been poorly insulated and required a higher BTU rating to maintain temps in colder weather. During our rebuild process, we will be fixing this issue with proper insulation. I think the comparison between Propex and Dometic renders Propex the victor on higher efficiency and lower power draw.
So essentially I have talked myself out of the Dometic and it is between Propex or Camco.
Leaning towards the Propex, but I'm concerned that it will not provide enough heat for the camper. Can anyone speak on this? We have a Falcon (smallest sized FWC no longer in production). Is anyone using a Propex HS2000 in a larger footprint FWC with success? If it works on a larger platform, it will likely be plenty for us in the Falcon.
You'll be happy with the Propex. I had an Olympian Wave in my prior Hawk and it provided adequate heat but I was always worried about maintaining adequate ventilation plus being super careful not to leave anything flammable near it. I have a Propex in my ATC and so far it's worked great. It's nice having warm air blowing throughout the camper especially in the overhead bed area. With the Wave it only seemed to heat up the area directly in front of it. You do hear the Propex but it's barely noticeable. I usually turn it on for 30-40 minutes in the morning and again in the evenings so power draw for me is minimal.
I put a 2200 in my Hawk, 2800 in the Puma. Happy with both. 2200 would probably have been enough for the puma too. Not as quiet as you might hope for, but not offensive
Thank you both for the advice! The HS2000 should be sufficient as our Falcon is much smaller than a Hawk. Also great points about not having to worry as much about things in front of the heating element while also getting better heat circulation. We will be going with a Propex HS2000.
Couple of questions:
Where did you purchase your Propex heaters?
Where did you end up mounting the unit and how did you run combustion intake and exhaust?
I bought from a Canadian dealer. I have pics in my build threads, but where to put it depends on so many factors! Do have interior pics/sketch of what else you anticipate putting near it?
Ah yes, I see now that you are up in Canada, makes sense but doesn't help me too much.
We are looking at trying to get our propane tank, heater, and batteries/electrical all in the driver's side rear corner cabinet that we will be building. I don't have any sketches that really help to visualize this at all yet. We are still very much in the planning stages, and I am still at work overseas. Shoot, I still haven't even seen the camper yet, just two more weeks.
I've had two different recommendations, one for mounting directly on the floor and drilling holes through the floorpack and composite bed of my Tacoma for combustion intake and exhaust. The other for mounting on the wing that overhangs the truck bedside, and drilling through the floor for combustion intake and exhaust. Always interested in other alternatives and options.
I'll check out the build thread for your Puma that you have on your signature for some more ideas.
I ordered my Propex HS2000 from Westy Ventures. Checking their website they are referring customers to Vancafe for Propex furnaces. During my ATC Panther shell build I had Marty pre-install the thru hull flue fitting near the bottom of the stove cabinet exiting the rear wall to save me the trouble of reto-fitting it later.
I should clarify, that when I drilled thru the floor of my Eagle and Ranger, the Eagle was bolted through the bed of the truck and NEVER, came off, I'm a full-time RVer, and my truck is my every day driver and is towed behind my motorhome. So I agree with Vic, if your camper is not bolted on and permanent, than the floor is probably not a good option
Aha! This is the solution I was searching for! Do you have pictures of how the heater is mounted and plumbed on the inside, as well as how you routed the ducting?
Vic Harder said:
Not the floor, unless you are never removing the camper, and can guarantee it will not shift!
This makes stupid sense to me now. Didn't think of it before.
So, allow me to go off on a tangent. Bolting your camper to the truck using the bed bolts. I assume your camper was designed to be mounted this way. My Falcon was also designed this way. However, FWC told me that the most secure method of mounting would be using their tie down bracket kit and turnbuckles and installing attachment points on the floorpack of the camper for the upper hook of the turnbuckles.
Is bolting the camper to the truck using the bed bolts a perfectly acceptable way to mount? Does it hold up to off-road use? We will also have the camper mounted permanently and living out of it for long periods. Are the turnbuckle mounts just for those who want to remove their camper more frequently?
Sorry,I don't have pics of the actual install. Here's a pic of the install diagram that came with the Propex. A 2nd pic showing the lower portion of my stove cabinet. I installed a shelf about 12" above the floor where the furnace sits. In the diagram the "sill of vehicle" is the rear wall of the camper. In the Pic of my cabinet the hot air outlet faces towards the front of the camper where the clothes pin is. The vent for the air inlet faces drivers side towards passenger side. The louvre on the left is for venting hot air in the cabinet. The combustion air and flue pipe exits under the shelf and connects to the thru hull flue fitting at the rear wall near the floor.
I seldom take pics of my mods as it's all I can do to keep focused on figuring things out. Hope this gives you a visual of my install. I've seen other installs and there are variations on how it can be done depending on the location.
This all looks highly logical, and I like the use of the thru-hull fitting on the back wall of the camper. Makes sense. Does the louvered vent also serve as your method of "return air" which the Propex utilizes? Do you find that you have sufficient air circulation with the placement of your air inlet and outlet vents?
Sorry- the hot air vent is the one upper right in relationship to the louvre. The other vent is the air inlet. The louver is for venting the cabinet. I'd say the hot air volume is somewhat minimal but it gives you a nice gentle heat.
Yep, I'm following. You have unheated air entering the round vent that faces the passenger side wall, heated air exiting the round vent by the clothesline, and any additional heat generated by the unit itself is allowed to flow through the rectangular louver into the camper and be utilized to heat up the air as well. I think it's great! Retains as much energy for as high of efficiency as possible and also provides air circulation in the camper by placement of the air inlet and outlet.
Latest posts
