mtn-high
Campground Host- FUNKYTOWN
One of the things I wanted to change on my Hawk from the get-go was the stock faucet. Not only was it huge and in the way, especially when it comes to packing cushions/pillows/etc. on top of the counter....but I also noticed that no matter what I did the control lever stuck straight up and touched the liner when the top was down.
Fearing that it would eventually wear a hole/weak spot in the liner, and looking forwad to the possibility of lengthening the bed rails for a change in the sleeping configuration of the top bed, I got out there (Amazingly..it was actually WARM outside) and replaced the stock FWC faucet with a Scandvik folding marine faucet I found on ebay (there are more auctions for these right now, they are $30 and a steal, IMO. You can get it in chrome or white).
As you may be able to see, this faucet is only about 2 inches tall and the bed slider above (once extended for the king) will easily clear it when pulled out.
I had to drill a new hole to accomodate the faucet and plug 2 other holes that were drilled for the stock faucet with chrome plugs...but all-in-all it went fairly smoothly.
I've yet to fire it up as it's still too cold here at night to fill the water tank, but it's in and everything is tight so I fully expect it to pass with flying colors.
I like it!
thanks for lookin' in
mtn
I like it!
mtn
