Flatbed Discussion
Nimbl Vehicles
Gandalf the Grey
May 3, 2010
413
Colfax, CA
Here are some sample picture of my flatbed in use.
It demonstrates the simple use of a deck compared to a traditional truck bed.
Side loading made easy for large items.
Is it going to fit?
Yup; it's loaded
Here is an example of using it for simple Garden Chores
Great use in tight spaces due to the side loading ability
Or just use it the way we are all used to
Being this is my 1st flatbed I have to say that I would never own a truck again without one.
Too much wasted space on a truck bed compared to the easy of using a flatbed makes me understand why they are so popular in Australia.
Just going to home depot the other day and loading a sheet of ply wood made life easy.
Simply drop one side; slide in the ply wood and you’re done.
So the question I have for you guys is:
Would you use the flatbed to it's potential?
How often do you remove the camper to do your honey do list?
Honey do made fun :p
Yes I would use a flatbed to its potential. Would be a lot better than the stock bed
My camper comes on an off depending on what I am doing. Firewood, Dump Runs, Landscaping, etc.
I think in the last few years the flat beds that have become avialable are really nice and don't really force you to change the way you use your truck. Flat bed manufacturers are now evening making shells for flatbeds so essentially you are just replacing a stock bed with a much more utilitarian one.
I will be replacing the bed on my 01 Taco very soon with a UTE...no question about it.
Cort
Seems like one problem with the low sides -- if you tried to transport those ponies they could easily jump out!
:D
I often day-dream of putting a flat-bed on my Dodge, but I'd lean towards a more permanent mounting with nice alum. storage boxes up and down each side in the gap between the camper and the flatbed. The one problem I can't get around (actually the first problem is $$$) is the height of the floor seems to go up about 6" with a flat bed. Do you find this negatively impacts the COG? Sort of, but not exactly, like this...
Also just out of curiousity, what is the weight difference going to a flat bed? I would guess you can pick up a bit towards the payload.
-Vic
-Vic
The hight is one thing I have thought about. Judging from my wheel wells, I think a flatbed would be about 9" higher than the stock bed.
Was just thinking about weight as well. My Tacoma has the composite bed, not sure of the weight difference.
Nice truck....but what caught my eye was the adornments in your backyard.
As we used to say years ago, "that's totally trippindicular, doood"
mtn
Vic has asked the right questions. I would add; flat beds limit tire and wheel choices.
We have a flat bed builder here in town. From the point of view of my interest in RVs, the outdoors and camping, they have a number of standard pickup beds around their business for sale, a good source for standard replacement truck beds. From what I see locally, flat beds are ordered by commercial businesses and farmers for doing work. Many are custom built and have headach racks to protect the cab from loads shifting forward, not needed for a camper. When I was farming years ago, we called these stake beds. Standard beds are cheaper and for light use.
Aside from that, I have a Reading utility bed that was under my Alaskan, now gone. As most people know here, Alaskans are heavier popup campers that work better on one ton trucks. A utility bed makes a lot of sense for one ton camper rigs. I would make someone a good deal on this old utility bed which has never been used for work. I will send a picture to anyone interested. John D
I believe that Ute Ltd makes a flat bed for the Gen 2 Taco. Actually they told me that their flatbeds will fit on anything. In terms of weight I have an 1st Gen Taco and they guys at Ute thought that their standard flat bed was about 100 lbs lighter than my stock bed. Especially when you consider that I have a spray in bedliner. Just rough numbers but it gives you and idea at least.
Cort
I think that depends on how you use the truck. For me I think it makes lots of sense. The one huge advantage is that you can gain a ton of storage space if you outfit it correctly.
Cort
How much sense do they make on a smaller platform like the Tacoma?
-Vic
No COG problems here :LOL:
You can save about 200 lbs on an aluminum flatbed over the stock ones.
I was just now looking at the Reading web site where specifications are provided on their products. I saw no utility bodies offered by Reading for smaller trucks. Looking at the weight specs; a steel 9 foot dually utility body, like the one I own, weighs about 1,500 pounds or 830 pounds in aluminum. I think it will take a one ton truck to comfortably carry utility bed plus camper.
One other thing, standard utility beds do not readily fit FWCs due to the way the floor pac is constructed. Thus, a utility style bed for a FWC/ATC would have to be custom. So, we are really considering Alaskans, XPCampers and hard sided campers with a straight up 4 foot wide floor pac if using an off the shelf Reading bed. John D
Yeah we aren't really looking at putting a stock camper on a flatbed. Several manufacturers, including FWC, Alaskan, and XP make models specifically for flatbeds (although the FWC and Alaskan versions are custom). Where did you get that weight for the flatbed? Did that include a bunch of accessories like cargo boxes? My understanding is that an aluminum flatbed is lighter than a stock bed.
I have not found anyone that makes an off the shelf utility bed for a smaller truck. I think this is mainly due to weight since many of the utility beds are still made out of steel. What you can do is get an aluminum flatbed from a company such as Ute Ltd and then customize it if you wish. The Ute aluminum flatbed is lighter than the stock bed.
Cort
I am running 35s and have no problems with them.
I could run up to 37s with that set up.
