Fleet Refurb Furnace Question
Serat
May 10, 2023
17
Colorado
Hi Everyone,
I just got my hands on a Fleet of unknown vintage (somewhere between 2006 and 2009, maybe) and I am refitting it. I figured I'd just pull the old furnace and pop a new Dometic model into the hole. The old furnace is a Dometic/Atwood 8516-IV. The guy I bought it from said it worked but I couldn't get it to light. Fan was okay, though.
The new furnaces are 3 inches longer than the old one. And, yes, I have learned an important lesson about removing something prior to researching a replacement!
My options seem to be:
1. Fix the old one (if possible) and put it back in. I saved the circuit board and thermostat but who knows if they work.
2. Cut 3 inches out of the wooden platform directly behind the furnace and get a new Dometic.
3. Try something entirely different like Propex or Truma (gasp$$).
I really want to go with option 2. Is there a problem if I cut down that little bump out where I drew the line in the photo? I would replace the wood on the end and patch the hole in the floor, of course.
Any advice for a newbie?
Thanks
Roylnn
Isn’t that round hole the access for setting the turnbuckle? I don’t have turnbuckles as my camper is bolted down to a flatbed, so I’m not the last word on advice. But, I believe that the turnbuckle will be angled towards the rear of the camper so make sure shortening that boxed area doesn’t interfere with properly installing the turnbuckle. Basically that box is to allow the camper to clear the inner wheel well.
Dean
TacomaAustin said:
Since you have the furnace out of the camper, my preference would be to have the existing Atwood 8516 unit repaired.
Exactly. Plus you will learn how the furnace works and how to repair it. There's not much difference between new and old in how they operate. Parts are available and there are repair videos on YouTube.
If it's the original control board, I suspect that's the issue. Did it start up and just not light? When I rebuilt my old Eagle, I replaced everything (sail switch, jets, etc.; all cheap) and then had to do the circuit board. I cleaned the flu, put a bit more insulation around the unit (top/sides), etc. I went with a Dinosaur brand and it worked great for many years until I sold the Eagle. Since it's out, you have a lot of options of what you could do (wiring, outlets, etc., etc.).
I thought I'd update this for those of you kind enough to reply. I did not have the courage to cut out that corner of wood, or the patience to become an HVAC technician so I have decided to get a new dometic and relocate it.
I may start a rebuild thread. Although, after reading several very complete threads on here, I doubt I'll have much to add!
Latest posts
