Has anyone found a sturdy table they mounted in the shell? I want one that will pop up and then fold flat down. I’ve seen the lagun brand but it doesn’t fold down. Thoughts?
Are you looking for something that goes from a horizontal (up) position to a vertical (down) position?
Are you making this or trying to find an existing solution?
Would it be used as a front or side dinette?
This is what I use in my Fleet shell. It does not pack flat, but can be totally removed and stowed away in a minute. In additional you can adjust size, height and orientation. A very flexible solution that works very well for me. More details at https://www.facebook.com/media/set/?set=oa.2831389866937091&type=3
I don’t know if there are smaller models, but the Northern Lite campers use a lifting mechanism that attaches to the wall, and pushes down from table height to be level with the surrounding seats. If I find a photo, I’ll attach it.
edit: here’s an image that gives you an idea, but doesn’t show much. It is articulated so the table goes straight down. The top slides side to side for people size considerations.
