Fridge Door Gasket Question
solarweasel
Jul 13, 2019
3
Durango, CO
My 2017 Fleet has an Isotherm Cruise 65 fridge. I've noticed that door doesn't seal very well, and always seems slightly ajar (and no, it's not set to "vent" mode). The reason seems to be the fridge door gasket at the bottom of the door having separated from the door itself.
I haven't figured out a way to "reset" the gasket manually so that it sits in there properly. It also doesn't seem like a replacement gasket can be purchased (but maybe I'm wrong).
Anybody else dealt with this and figured out a solution? A couple of photos attached; one of the door ajar, and another from the bottom up of the separated gasket.
That's a very large gap shown in the picture, hard to tell but you might have another issue along with the gasket. Maybe a warped door or worn hinge or hinge bushings, hinge alignment?
I you search on the forum, I posted a "report" (I think) on how I replaced my refrigerator gasket. It wasn't easy or difficult but trying to find the right gasket and getting it made was a little difficult (getting it made was easy, find the right gasket wasn't quite so easy). The gasket I bought was a bit too thick but it worked and the old gasket of 20 years was pretty shot. This was on an old 3-way refrig that supposedly had a gasket that wasn't replaceable (by dometic) :)
Latest posts
