Update time. We have been out a few times in cooler weather, so have had a chance to check out the Propex furnace.
First - it works! Noisier than I had hoped. Can't compare to much of anything else though, since the other noisemakers in the camper are only the 130L Truckfridge (near silent) and the Fantastic Fan (noisy!).
Second - I had to tweek my install. I had a problem with the furnace not lighting, (turns out to have been user error, as I didn't tighten the propane hose onto the tank tight enough to open the valve - small burr had me thinking it was "on", had to push past that resistance to really get it on), and learned a few things from the excellent support folks at Propex Canada (Chris Ball).
- The exhaust hose gets really hot (250*) and needs to be protected. These units normally go into "Caravans" with metal bodies/floors. When installing in a wooden camper, we need to take extra precautions. Also, I mounted mine in a really tight spot, so need to take extra extra precautions! See more info below...
- There is a fuse on the circuit board! This can be really hard to get at, depending on how the furnace is mounted. Take a look at it when you are connecting the wires and have the cover off. JPG attached with details here:
I got this PDF from Propex Canada, when we were troubleshooting why the furnace wouldn't light up. The fuse on mine was not blown, but it was good to find out where it was.
So I made a few mods to ensure the hot stuff on the heater does not get in contact with wood. I had initially routed the flame exhaust like this:
It now goes through an aluminum plate, with the hole just big enough for the supplied silicone rubber sleeve to fit, and sealed with red high temp silicone for use on engines and other super hot items. The hole behind the alum has been enlarged to 2", so there is lots of room around the exhaust hose.
I also added another hose clamp to secure the hose and keep the down angle consistent (for condensation drainage) and added some 1" long metal stand-offs to keep the hose away from the camper's wooden surfaces.
Finally, I added a piece of angle alum inside the camper, to shield the hot air hose from the hot exhaust hose. There is about 3" clearance there, and the hot exhaust hose rests on top of the alum angle. I could also add a sheet of silicone rubber on top of the angle alum at some point, as the alum angle still gets pretty hot.
Also, the way I had the hot air exiting and blowing onto the water pump, and hose fittings on the end of the water tank, meant that there wasn't a lot of air flow coming out of the heater. Too many obstructions as you can see in the image below. So I am going to be adding some more length to that hose and running it beside all those components, and still exiting down low as planned, but with a hose to run through the whole way. Gotta go to HomeDepot and grab some dryer vent hose for that.
The next project is adding a better thermostat. We tested out the existing one last weekend, and on the lowest setting it heats the camper to 15*C. Too warm for me at night. I'd like to get a "freeze protect" setting of around 5*. I got this info from Propex Canada and need to splice in a thermostat to give me finer control.
Ideas on how to do that would be appreciated. There are a few links out there, (this is a great general install page
https://faroutride.com/propex-install/ )
but nothing super clear on how to wire in an additional thermostat.
