Nearlyroadready
Throwing the question out there: Has anybody replaced just the upper level wing on their fwc camper? I don't have time presently to replace the whole floor pack but need to either reinforce the wing with some new plywood or replace it.
I would see reinforcing it as just sandwiching the old rotten wood between two new pieces of plywood and then caulking the joints that allowed the old wood to rot in the first place. Simple, easy effective. That being said, is it worth my time to take off all the exterior trim, remove the old piece of wood and then replace? Anybody know how much time this takes? I have access to all the tools and could make time if it's worth it. Otherwise, going simple seems legit. Thanks for the thoughts in advance!
Luke
Note: The wood is only rotten and soft for the last 6 inches of the wing. In the photo, it all looks rotten, but it is fairly minimal. The paint has peeled from the whole bottom of the camper. Also, this is bolted into the truck, so the wings are not bearing the brunt of the weight.
Luke
