Fwc L bracket for bench
CaptRussia253
Jan 31, 2018
94
Tri-Cities, WA
I removed the metal drawer from the previous owner and now need to replace 16" of the 1x1 black L brackets for the bench. Anyone know where I can buy it from or where fwc gets there's from?
Thanks
More info is required. What is the bench? Can you provide pics?
It's a shell model. The bench I'm referring to is what the fridge is sitting on. I need the black trim piece that is on the edge of the bench.
Hello CaptRussia253
I’m just guessing but it’s probably 1 “ black anodized aluminum angle. Do a google search and you can probably acquire that way. Plenty of companies selling on net. Small order like that would be the way to go IMO. You would have to do the anchor holes.
Hope this helps.
Russ
A good hardware store or even Home Depot sells mill finish aluminum angle. Cut it to length, drill holes, deburr, prime and Paint. save the shipping $.
Ya so calling FWC was no help.
I went down to Lowes and got 1x1 aluminum angle for $4. Cut it to length, drilled holes, deburred and painted.
The drawer was a custom built from the previous owner and only took 10 minutes to remove. It wasn't anything special.
