Hydraulic Fluid Used in System
Kurtdeetz
Jan 26, 2015
3
Hello
Was able to replace the leaky O rings pretty easy. Found out through the original paperwork that the hydraulic fluid to be used is a Mil Spec type they no longer make. Aero Shell 4 when I reserched was a compatible replacement. Any suggestion of what is best to use and where to get my hands on some? Loving this forum, some great info!
Kurtdeetz said:
Hello
Check with an aviation maintenance supply for a substitute. You should be able to find it on line.
Edit: there seems to be a lot of it... https://www.google.com/#q=shell+aeroshell+fluid+4
I was using power steering fluid but found it to thick in the cold weather so I switch to auto transmission fluid. It works fine, never gets hot enough to thin out also doesn't bypass the o-rings. Not my idea someone else told me about it but can't remember who. I have used it for 3-4 years everything seems OK.
Latest posts
