Hypervent?
DBAshland
May 29, 2021
8
Ashland, OR
Getting ready to order marine hypervent for our Hawk. Does it only need to be installed under the mattress that's in the cabover part, or should I get enough to also go under the mattress of slide-out portion of bed?
There are a couple brands I've found online: "Genuine Hypervent" and "Aire Flow Hypervent". Any pros and cons? Preferences?
1 Comment
Like
Comment
Share
Since the slide is inside the camper, it doesn’t get exposed to the cold like the cabover section. I don’t believe it’s necessary. My new cougar will only have it on the cabover.
I put it under the whole bed. It’s flatter that way, and there has to be a way for the moisture at the front of the bed to make it out the back (closest to the back of the truck) to make it out from under the bed.
I have the genuine HyperVent product in my camper for 7 years now. Works great and there hasn’t been any comprehension or deforestation. HyperVent has a special right now on their website, $9.99 per foot for 40” width., that seems to be about what the knockoff costs.
Dean
The HyperVent people address the difference between HyperVent and Hypervent Aire-Flow on the home page as you scroll down.
I decided to use another product instead of HyperVent. The HyPUR-Flo product from Tochta has the same purpose at about the same price but is slightly thinner (1/2" instead of 3/4" thick) and has a smoother top/bottom surface that I believe is less likely to snag on fitted sheets and the slider board. The thinner aspect was important to me because I wanted every inch between the cabover floor and the ceiling to be available for the mattress and topper. I managed to squeeze in the original 4" foam (without the covers), 2" memory foam topper, and a fitted quilted cover (so I don't have to lie directly on the memory foam).
Here's the link to the Tochta HyPUR-Flo product. I also got fitted sheets and the quilted topper from them - these were made to an exact fit to the mattress dimensions I provided. https://www.tochta.com/product/hypur-flo-moisture-protection/
AdventureDave, I'm considering the HyPUR-Flo product for the same reasons you mentioned -- less friction moving the slider board in and out, and thinner, since I'd fold it up along the cushion edges so vapor can escape, without the cushion up against the wet wall surface.
How's it been working for you so far? Do you find the 1/2" thickness enough to keep the cushion dry?
Appreciate any thoughts.
