Initial water tank fill on Fleet
pettestaats
Mar 26, 2023
1
We have a Fleet which we have filled with water over ten times. We are filling it after our winter and it will not allow us to fill the tank. Water keeps gushing out of the little wire filter between the two fill spots.
Does anyone know a solution to this problem?
Thanks
How many gallons of water have you put in before it flows out of the vent.at the filler?
Have you drained the water out to empty and started over and measure how much you put in?
Implied and I agree, that perhaps the tank is full and hence the overflow is what you are seeing...unless there is an ice plug, not sure what else could obstruct that 'closed' system...FYI, we open both faucet valves when filling....
Persons first post, just have to wait for said person to come back to post more information if person still needs help.
