Introduction and turnbuckle tip
OtherHand
Mar 17, 2008
2
I just wanted to decloak and say "hi". I owned a FWC Ranger II from 1994 to about 2000, on a 95 Tacoma Tundra. Liked it a lot, did a number of mods but finally sold it when circumstances changed. I now have a 07 Tacoma, and have been considering returning to those good old days. I am just stunned at the amount of modification info now available for these campers on the Internets. That wasn't the case in the 1990's!
And now I offer up something from my experience with turnbuckles from those days. Yeah, I know the factory says they seldom come loose, but with enthusiastic 4wheeling, I experienced otherwise. My fix was simple and cheap. On each turnbuckle I drilled about a 1/16" dia hole though one of the two threaded pieces, near the end. I had to be cautious not to damage the threading. I then went ahead and installed the turnbuckle until it was tight, and the hole was pointing out between the sides of the turnbuckle frame. I then slipped a "hairpin cotter pin" (Google it) through the hole in the thread. These things just snap in and out. But they stick out enough to prevent the threaded portion from turning. If it starts to do so, the clip hits the turnbuckle frame and stops the rotation.
I drilled the holes in the threaded portion in the same plane as the hooks, so it had the added benefit of letting me know, by feel, where the hooks were pointing when I was attaching the turnbuckles to the eyebolts.
It was such a simple and positive safety, I never could figure out why it wasn't done at the factory.
Tom
Ooops! Sorry, my mind said Tacoma and I typed Tundra. What I got was one of the very first 3.4L engined Tacomas, which finally had enough power to comfortably haul the FWC. It had previously been on a 94 3.0 L Toyota pickup, which really didn't have the power to carry the camper.
Yeah, a Ranger II on a Tundra would sure leave a lot of room left over to haul other things in the bed....
I have dealt with this turnbuckle thing one way since 1994 and it's never failed me. I "inherited" some very large nails. Don't know the size, but these suckers are at least 9" long. Once I get the turnbuckles tightened, I throw one of these nails through the opening between the threads in the middle of the housing or cage of the turnbuckle. The Nail head prevents it from slipping out, and gravity does the rest. If the turbuckle tries to escape, The pointed end of the nail hits the side of the bed, and stops. Occasionally, I'll tape the nail in place if I know I'll be trashing my truck, AKA, very bumpy route. I have a spray in bed liner. If I didn't, I'd put duct tape on the (pointed) end of the nail to prevent it from scratching the paint in the bed.
I'm getting ready for a desert trip and if I get time, will post a pic or two.
Happy Trails
hayduke is right! simple and easy.
Even better would be something made of nylon or fiberglass......it does not have to be as tough as a nail really.
i used a length of dowel .... i was thinking of making a "knob" of epoxy at one end to prevent it from slipping through. nylon would be better....do they make nylon rod ?
O.H.
Just razzin you a bit on the typo...
I run a Ranger on a 2002 Tundra. Although I haven't figured out how to best utilize the space, there is a ton of it in the bed around the camper...If I was going to go buy a new camper for the Tundra, I would get the Hawk..
TT
At the risk of offending those over engineered turn buckles I just put another nut on one of the threads and tighten it after the turn buckle is cinched up. Works fine doesnt loosen and its simiple. As most of you know I subscribe to the KISS theory.
If you wanted to be fancy you could get reverse thread nuts. Any way I just lightly cinch them up with an open end. I've never had them come loose. I do still check the turn buckles after a long ride on a rough road. Anal retentive I guess.
