IOTA Wiring Questions
coloradoclimber97
Jan 16, 2018
35
Quick couple of questions for someone familiar with wiring an IOTA DLS-15/IQ4 power converter/battery charger in a system with a BMV -712 battery monitor.
Do I wire both the positive and negative from the IOTA straight to the batteries, or does the negative go to the shunt on the 712?
Do I need a inline fuse on the positive side from the IOTA to the battery?
And finally, do I need to use the chassis ground terminal on the IOTA?
Thanks,
Mark
Have wired IOTA 55 with Trimetric meter. You need to wire negative to shut otherwise you won't account for the charging amps and your capacity numbers will be off. The IOTA manual I have states that it requires a type III breaker on "RV installations". Chassis ground should be attached as well.
Thanks for the input, tbair, I will proceed accordingly. What I don't understand is why the fuse is required when there is one built in to the IOTA unit.
On another note, my solar system is setup and running smoothly thanks to all of you who contribute to this site. I truly would have been deaf, dumb and blind if it weren't for all the great advice I gleamed from WTW. I love my Victron 712 and MPPT controller!
Now hopefully it's off to Baja this winter with all my power requirements in the bag.
Thanks again everyone!
Mark
I emailed Iota Tech Support a few days ago on the issue of why the positive-line fuse is required.
My questions (using a DLS-45 as an example):
" IOTA Product: DLS-45
Question:
Could you explain why a type III circuit breaker is needed in RV applications?
I understand the reverse polarity fuse(s) will blow if polarity is reversed or 12v current draw exceeds 60 amps.
Offhand, I thought perhaps the type III circuit breaker is a backup in case something goes wrong with the DLS-45's fuse system. But if that were the case, I'd think the same logic would apply to non-RV applications.
And why a type III circuit breaker (as opposed to other fuses or circuit breaker types)?
Is that requirement an RV-industry safety requirement or something?"
The response....
"A overcurrent protection within 18" from the converter is an RV requirement.
It doesn't have to be a type 3 breaker, we only mention it as an example recommendation.
It can also be a glass fuse, auto fuse, or a circuit breaker."
I called in this afternoon and the same tech answered. I again asked why the requirement for RVs but not other types of installations and explained why I'm asking. He said he only knows it's a requirement for RVs and speculated it's there because other converters may not have the internal fuses (which could be true but I was hoping for something more definitive).
I also asked if he meant 18" from the battery rather than the converter for the protection. He re-iterated it's the converter. (The manual clearly says battery so I think there could have been some confusion there.)...
(copied from the manual)....
"Recreational vehicle applications require a type III circuit breaker be installed within 18″ of the battery, connecting the battery positive to the line side of the breaker, and the IOTA unit to the load side. Connect 'Chassis Bonding Lug' on the IOTA unit to vehicle chassis or other grounding source"
Perhaps it is a artifact from some RV industry convention or spec, ie maybe RVIA requires it so it is listed in the manual. On the other hand I don't think the reverse polarity fuses will protect against a short. I don't know, but I am of the mind that more fuses are better than fewer fuses and put one in my installation.
