I would like to mount a jerry can seat to the back of my Eagle. Any suggestions on where to mount, what type of screws, etc...Ideally, I would like to bolt it into the aluminum frame, but don't know how to locate the studs.
Marty discovered awhile back that a stud finder will work to locate the studs on the camper. He used it on the inside to locate them. If you are going to mount a can on the back, you will want to bolt the holder all the way through the wall and use some cap nuts on the inside so that it will look ok and you won't have a bolt end sticking through that you can run into.
If you are going to through bolt it on the rear wall of the camper, you will probably have to remove the camper trim and peal back the aluminum siding to get an accurate locating of the framing. It might be done other ways, but you probably don't want to miss the frame by mistake and have an extra hole there
The easier way might be to fabricate a bracket and mount the can to the "jack bracket" if you have them, or to the bumber.
