L track on outside of camper
strotman
Jan 26, 2016
13
Has anyone installed L track on the outside of the camper to carry things like shovel/axe recovery boards etc. Looking to add some to my camper but looking or advice and pictures before I do.
I am considering something similar. Some of the flat beds have two parallel tracks off the back, I think they are are heavy steal.
I have a shell and may experiment with running two 80/20 aluminum T-tracks along the driver side between the jack brackets.
I have 80/20 across the jack brackets on the back of my flatbed and use it to carry recovery boards and mount my cell booster antenna. It works well. My experience with L-track is using it for tie downs - how would you secure something besides tie downs to it?
The 80/20 makes more sense, more versatile. Not sure that I'd want much of anything on the sides of the camper though. Ron
It is an idea, but that stuff is heavy. But that looks like an Alaskan. And with the way the camper opens he is limited to the sides.
Russ
For L-track there are fittings made with threads. A member here showed them to me, he used to use them to secure his bed shell in place. Examples:
http://www.uscargocontrol.com/Ratchet-Straps-Tie-Downs/L-Track-Stud-Fittings-Accessories/Double-Stud-Fitting-w-Bolt-Thread
http://www.uscargocontrol.com/Ratchet-Straps-Tie-Downs/L-Track-Stud-Fittings-Accessories/L-Track-Double-Lug-Threaded-Stud-Fitting
Since you're likely to only need one of the slots in an 80/20 extrusion I'd use this: https://8020.net/shop/1050.html
or this: https://8020.net/shop/1050-black-fb.html (but note the substantial price difference!). With the right OD counter-sink could drill and c-sink where you need to and have screws flush to the bottom of the slot w/o compromising the rail.
There is also a two parallel slot extrusion made: https://8020.net/shop/2012.html & https://8020.net/shop/2012-black-fb.html
I see L-track as being more adaptable to short term needs and 80/20 more useful for longer term installs. Primarily because it is quicker & easier to place an anchor in the middle of L-track than it is in 80/20. Can be done w/o too much pain with 80/20, but L-track is faster & easier still.
If you go with the t-slot like the 80/20, you could use rectangular head bolts for quick installs, they come in lots of lengths too. I have L- track on the inside and use it for rings, to tie things down, there are really limited fittings for L-track. The bolt on version is only 1 size and one length, so for instance, you could not mount a long bolt and send it through your shovel shaft, and it is too thick for most quick fists.
Depending on what type of 80/20 you get, you can get the ends tapped so you could bolt them to the jack stands.
My $0.02
