Mitsubishi Fuso FG Expedition Vehicle $150000.00 CAN
Nimbl Vehicles
Gandalf the Grey
May 3, 2010
413
Colfax, CA
I am posting this for a customer of mine: This camper also is removable which makes it a dual purpose vehicle :LOL:
Mitsubishi Fuso FG Expedition Vehicle Truck
-2005 Mitsubishi Fuso 4X4.
-47,000 kms.
-DOHC 4-stroke cycle, water cooled, turbocharged, inter-cooled diesel.
-In-line four cylinder.
-147 hp @ 2700 rpm / 347 lb.-ft. @ 1600 rpm
-5 speed OD MT with 2 speed transfer case
-Auxiliary fuel tank mounted (125 litres); total fuel capacity 250 litres.
-Aluminum custom toolboxes mounted under bed on each side.
-Aluminum flat-deck (multiple tie-down points) with hidden fifth wheel hitch.
-Suspension redone to match weight of vehicle; new leaf package, Bilstein 5100 nickel plated shocks, new brake
lines and steering arm.
-Stockton Wheel rims 16X8 mounted with Goodyear Wrangler Duratrac 315/75R16.
-Yakima Load Warrior & extension, Yakima spare tire carrier.
-PIAA 525 plasma driving lights encased in bush bar, Hella manually directed spotlight, reverse spotlight.
-Alpine IDAX305 i-pod ready stereo and Alpine speakers.
-Air ride drivers seat.
-Heavy duty 2.5 inch hitch.
-Full maintenance records since new.
Camper.
-Custom aluminum removable camper.
-Maple panelling, cork floors and stainless steel cabinets and hardware throughout.
-Stainless Steel Marine Grade Appliances; Force 10 heater, Dickinson 2-burner drop down stove, Dometic sink,
National Luna 90 litre fridge/freezer.
-100 litre fresh water, 50 litre grey water, stainless steel water filler and city water hookup.
-40 lb. propane tank in side storage unit.
-Custom 2-way privacy blinds.
-Power; 4 X 6V Interstate deep-cycle batteries charged via vehicle, shore power or solar panel, 12 volt DC or 110
volt AC outlets with inverter.
-Thule-pro rack with Spirit 1600 box; Cargo box fits two surfboards or six pairs of skis or four snowboards in addition
to Rack which fits longboards or kayak/canoe.
-Custom aluminum ladder leads to roof.
-Barn doors at rear for easy loading of bikes/motorcycles.
-Reico Titan camper jacks, easy on-off for varied usage.
-Use the truck for work and the camper for play
-Only a superficial list on this one of a kind expedition camper. No expense spared.
-Serious inquiries only please.
Dimensions
A. Usable cab to rear axle 87.4" 111.0"
B. Wheelbase 112.6" 136.2"
C. Overall length (end of frame) 200.3" 223.9"
Body size accommodated 12' 14' 16'
Weight (lb.)*
GVWR/GAWR 14,050 Front 5,730 Rear 9,480
GCWR 17,045
Max. body-payload capacity 8,208
$150000.00
Interested parties can e-mail marc@xpcamper dot com and i will get you in touch with the seller.
This Vehicle is located in Canada!!
Pods
You cracked me up with that one. I noticed the $150 also. The only reason I didn't point that out to Marc is I've met the guy. He butchers the English language so bad, I'm not surprised he can't deal with standard units vs metric. :p
Marc,
Seriously though, you say the sellers are clients of yours. Good for you and for them. IMO, they will be getting a nicer expedition vehicle for less $ than their current one. A smart move.
