Modifying Alaskan Campers
Vic Harder
Doctor Electric
Site Team
Nov 14, 2015
5,236
Calgary, Alberta
Still looking at Alaskan campers and trying to decide if I want to take the plunge into a wooden framed camper. Wondering a few things:
- Can the camper be easily modified?
- As in, do the inside wall panels, cabinets etc all come off easily so you can access the wiring, plumbing etc?
- Can a roof rack be added, or is the roof reinforced at build time for those?
Also, I saw a camper recently that had this damage? What's involved in repairing that?
One owner's "easy" is another's "impossible," but a lot of owners find DIY repairs and refurbishing to be quite feasible. Basically these things are built from the inside out and repaired from the outside in. They come in two pieces, the upper shell and the lower shell, which are easily separated. Pull off the aluminum skin (attached with staples, mostly), and the entire upper shell wooden frame is laid bare (with fore and aft plywood bulkheads), and that exposes the upper shell wiring. The lower shell is basically a 3/4" plywood box with cabinets screwed to it. The plumbing is pretty basic, since there's just a water inlet, a drain outlet, a sink with faucet, and a water tank. The upper shell cabinets are really easy to remove/replace. The inner wall panels, not so. The rigorous approach is to totally disassemble the upper shell frame, then the panels can be removed from the bulkheads. The sloppy approach (which I followed) is to cut out the panels from the inside and fit replacements with very close tolerances. It's a tedious business but feasible.
Easy to add, on the back it screws to the rear bulkhead and at the front end it screws to the frame members adjacent to the fore bulkhead (which is the midships bulkhead on cabover models). Note that the payload capacity for the upper shell is 250 lbs which includes everything you store in the upper shell cabinets, plus the weight of the rack and hardware, plus whatever you put on the rack.
Pull the aluminum skin and assess/repair damage to the underlying bulkhead and frame. Replace the skin, seal the joint with butyl tape or suitable sealant, and protect it with some lightweight aluminum angle iron.
I have added lithium, solar, 12V fridge, vent fan, hot water, diesel heater, kitchen remodel, and all sorts of other stuff without tearing the skins off or separating the halves of my 1965. I thought it was pretty easy. You can always add access doors to the lower half if you want to, uh, access things easier from the outside.
I wouldn't trust an older one to hold much weight on the roof, it's only 1"x 2" construction, and for me, that's just asking for trouble. No idea how the newer ones are built. The old roof racks are really more like front and rear bulkhead racks, weight does not actually rest on the roof skin.
I have some build pics linked in my sig. I went from worthless electrical, icebox, and hand pump sink into most of what you see in just a couple weeks of working on it. Helped that I had a lot of the "stuff" from another camper build.
Take your time looking, and start with a solid of a shell as you can find.
Thanks Bos_Tok and Dr.Science! That series of teardown & rebuild videos of ‘76 were enlightening. Although I am not so sure (haven’t finished watching all of them) he made it any lighter, substituting 2x4 for 2x2 in places didn’t help.
