Land-roamer
I'm curious as to what kind of modifications, slight or serious, some of you may have done to the inside of your Alaskan camper, to suit it to your particular needs or configure it for different purposes.
Most of the photos I see online and in the gallery seem to show pretty stock interiors in them, but I'm just wondering what might be some worthwhile modifications to consider, if one was going to be traveling solo with it for example, and want some more flexibility in things to do inside when the weather turns bad.
An example of a "bad" modification (in my mind anyway) was the previous owner of mine, who took out the 3 way fridge and replaced it with a 120v bar fridge (which I've taken out), which involved him doing some dubious work on the stock woodwork to make it fit. I'm trying to figure out what to best do with that space now, whether I should remove the metal vented cover for the original fridge and replace it with a flat piece of aluminum.
The other thing I'm looking at is this sort of white canvas bag located under the sink, which projects out into the space between the camper bottom and the truck bed side. I have no idea what this was used for or whether it would be useful for me, or what to do with it.
Anyway, any suggestion or pictures of modifications you've done would be an interesting topic I would think (unless it's been covered before, in which case I apologize for bringing it up). Thanks.
--Robert
--Robert
