Hello, been lurking here the past couple months while waiting for my Ocelot shell. The day has finally come and I will be driving out to Sacramento from N Utah next week to pick it up. I will make sure and post some pics up when I can.
Ocelot shell 78" 3 way fridge, furnace, extra roof vent w/ fantastic fan, aux battery, 12v acc plug, slide out for extended bed, wire camper for solar, yakima tracks 72", also having them build out some cabinets on drivers side. It is going on 06 Tundra Doublecab(92k) w/ Firestone airbags & General Grabber AT2 load range E tires. Hoping it will fit in garage, have 93.5" to work with, gonna be close.
I have several questions regarding things im going to do right away, and I wanted to see if I could get some expert opinions. Thanks in advance!
1. I have purchased an ARB awning to put on pass side. Ive seen both bolts and self tappers used for installing the track, looks like there is an aluminum strip that runs along the top of the camper that I will verify w/ Marty,any pros or cons to either?
2. Rotopax vs At jerry can mount?
3. Installing a "T" on exterior propane tank for outdoor cooking? I specced it w/ a 3 way fridge and furnace so I will have the onboard propane. This was something I wanted to see if Marty could do but forgot before my build was done![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
4. Mounting Renogy 2x100 w panels with pwm controller? My camper will be prewired so it shouldn't be too big a job, just wondering if it is worth upgrading to mppt?
