Rigid foam insulation under cabover on Bobcat
frigid north
Dec 25, 2011
17
Anchorage, Alaska
Hello everyone, I have been asked about this modification so here are some photos.
I added a 2" foam panel to the underside of the cabover. I used stainless steel screws set thru the angle into the frame around the edge of the bed. I used Gorilla glue to secure it, the gorilla glue does not attack the foam. I used 1/8" red oak ply to cover the bottom. I used 2X2 aluminum angle to trim the edges.
So far it is holding up well, and it keeps the camper bed warmer, and eliminates the condensation that builds up under the foam mattress in cold temps.
I have been adding rigid foam to every surface of the camper that I can. I added foam to the outside areas that are next to the bed, and I have added a 1/2" rigid foam to all the surfaces on the inside. The camper is now warmer in the winter months.
Nice job- I'm always interested in ideas to keep the camper warm in cold times. Thanks for posting your solution.
Nice job, frigid. Any ideas for the forward lower walls and the floor? Have you looked in the wall cavities to see any of the factory insulation? Just curious how well they insulated. I assume you use the arctic pak? What thermostat do you use to keep the temp somewhat stable in cold conditions? I havn't used my camper much below zero.....just too much condensation and hard to keep comfortable. Thanks for sharing.
Hello AK NOMAD,
I have been adding rigid foam everywhere that I can, outside and inside, I added a 1/2" layer on the floor, inside the camper. I have not looked in the walls but I know there is one inch of glass bat, not much insulation but it is a light weight camper. I have added a 1/2" layer of rigid foam covered with a very thin oak veneer to the inside surfaces of the camper, this a light weight addition to the camper that adds some comfort.
I do have a custom made arctic pack that I had Alaska Tent and Tarp make for me, its a nylon fabric with a synthetic insulation sewn inside like a sleeping bag, these panels velcro in place just like the original arctic pac panels, in fact I took those panels to them so they would have a pattern to copy.
I am using an Atwood thermostat with the propane forced air furnace that ATC installed. I have used camper in temps down to -40 F once while driving thru the Yukon, it was so cold I didnt even pop the top I just slept on floor of camper. The camper is warmer now with the xtra insulation but I do get condensation on the ceiling where the aluminum frame is, the aluminum conducts the cold well, if there were a thermal break of some kind between the aluminum and the outside i think it would reduce the condensation. Even a 1/2" layer of rigid foam, it wouldnt add too much wieght. I have thought about a new roof design where the whole thing is covered in rigid foam before the final skin goes on.
If I had to put a tempurature rating on the camper now I think that I have a camper that is comfortable to about -9 degrees F.
Never mind, I was able to zoom and see the wedges cut out, and then welded?
Latest posts
