Mykiss
Hello guys,
I was told initially, that my panther shell will be done sometime in January 2022, but it seems that the guys ramped up the production and I may be able to get it in the Fall, if travel to US is possible.
Would you consider installing a roof rack if you had to do it again? Biggest concern is the possibility of water leakage, and high cost vs usage. I would use it mostly for bulky light items as the clam tent, camping chairs, solar panel.
No Yakima available at ATC, for now, due to supply issues. Has anyone installed Rhino racks?
What kind of fixture do you have installed, to allow the cables from the camper exit and connect the truck cable(via anderson connector), my plan is to use a 2awg cable(unfortunately ATC can't install larger cables so I will have to do it myself).
Do any of you have a portable electrical system contained in a heavy duty box(let's say LxWxH 2.5'x20"x2') that could be removed in the Winter? All the wires/cables entering the box could be disconnected( if connectors installed) at the entrance/exit to box. Box could be used as seat at the front of camper...I was thinking to get a Kisae MPTT/DC-DC and an Inverter/Ac-DC charger. I have a DIY Lifepo4 battery.
Do you have a modular kitchen system(rather than fixed cabinets) that can be moved outside when needed ?
Do any of you have switches to lights on the wall by the entrance rather than gang switches on the cabinets?
I ordered a Maxxi fan, but heard they need a voltage regulator as they don't tolerate higher voltage than 13V, anyone installed one?
Is that bed extension worth 375$? Isn't it just a piece of plywood sliding in and out? Are there some fancy rollers? Is it difficult to insert ?
Thank you for all your answers
