Hello,
I got my internal lifting struts installed and used them for a few nights recently. I noticed 2 things that concerned me and am wondering what you all see:
This 40-second video shows lowering the roof. The front comes down great (I actually have to help the struts compress). Then, when I release the back, around the 23 second mark, the driver's side jumps up a little and the roof comes down crooked. To me it seems like that's a bad thing -- I don't think the piano hinges holding the lifting panels want to move that way. But maybe I'm being nitpicky.
Do you all have roofs that lower that way, would you worry about it if you did?
FYI, I think all the mounts are evenly spaced: the brackets on the driver's side are within 1/4 inch front/back and side/side of where they are on the passenger side. The passenger mount, I confess, is a tiny bit crooked, but I think with the play in the eyelet on the pin (there is a lot of freedom to move there) it doesn't affect how the rod pushes. In other words, I don't think the strut is pushing anywhere except straight up to the roof bracket.
Bonus question: do you think the bracket is crooked enough to matter?
Thanks for any ideas.
Buckling below
The metal backing is straight, the bracket is a little off
Let's get the lighting to really accentuate the imperfection...
- The wood strip along the ceiling buckles a little when the top is down (it's less noticeable now than when I took the picture, but it's still there)
- The roof doesn't come down completely straight
Buckling below
