Hobart78
I have the 2014 Hawk on a 2013 Chevy Silverado 1500. I had the top and back solar plugs installed.
I'm in the process of installing two 100 Watt Renogy solar panels (framed), 500 amp shunt, Tri Metric battery system monitor, and the SC-2030 solar charge controller. I have all of the above installed except for the solar panels. I'm waiting for a warmer day for that. Question I have is does the FWC inverter need to be attached to the shunt? What I have attached to the shunt now:
Left side Right side
Negative from batteries Truck alternator negative
Wire from Tri Metric Solar charge controller negative
Wires from Tri Metric
The Tri Metric is giving me readings although I haven't programmed it yet. This is going to be much better than the four light system for battery status.
Thanks in advance for the help. I won't get back to the forum till this evening.
George
George
