BobD
I'm using a Morningstar Controller MPPT-15L an a FWC Eagle. Where do I make the "load" connection? I initially attached directly to the Blue Sea fuse panel but that immediately powers everything while the panel is in direct sunlight regardless of the FWC Main 12VDC On/Off switch. I'm assuming that I should be on the +12VDC side of the FWC Main 12VDC On/Off switch? I tried a search but ended up chasing my tail...
