We are selling are much loved 2002 Ford F350 crew cab long bed and Grandby camper.
This truck has been a great vehicle but it was time for us to upgrade. We are the second owners of this truck and its first life began with my neighbors using it a couple times of year for road trips to the coast with their camper. I got the truck at 40,000 miles and have taken it to 156,000.
I built this truck out for us to take family camping trips to pretty remote areas; as such, I have done a lot of upgrades. The most important upgrade I didn’t do, is mess with the engine or exhaust. I have never chipped or otherwise put any sort of tune or performance upgrade. This truck has plenty of power and reliability without messing with the engine. I did do some longevity upgrades as listed below.
I bought the Granby camper after selling our Syncro because we needed more space for our family. It was originally a 1979 that I completely gutted and rebuilt twice. The first rebuild was putting in all new systems and interior and reframing the floor to fit in a newer truck bed. The second rebuild was last year when we completely resided the exterior, and did other upgrades as listed below.
This truck and camper combination is ready as it sits to take you anywhere in North or South America. This truck is almost 20 years old and barely broken in, however as with any older truck there are idiosyncrasies, and little things that can be finicky. I would not hesitate to take this truck on a trip, but before you do, I will completely go over all the upgrades and familiarize you with it.
Sold as a package at $30,000 OBO We are willing to separate
Pros/Upgrades:
![](/proxy.php?image=https%3A%2F%2Fexpeditionportal.com%2Fforum%2Fdata%2Fattachments%2F519%2F519864-b6000a261926b9d3ed53876c3af59173.jpg&hash=4dd8a94079c1d49da4588da0205eb2d3)
![](/proxy.php?image=https%3A%2F%2Fexpeditionportal.com%2Fforum%2Fdata%2Fattachments%2F519%2F519857-02c3af6b51ca2a2e5fc7f641d2317dfa.jpg&hash=5f3cb0e0353ebeb27d635948da800c19)
![](/proxy.php?image=https%3A%2F%2Fexpeditionportal.com%2Fforum%2Fdata%2Fattachments%2F519%2F519859-384cceec0c9915e7e1761ba0163a3ae7.jpg&hash=8914b37c770d66ab330432cec6c09464)
![](/proxy.php?image=https%3A%2F%2Fexpeditionportal.com%2Fforum%2Fdata%2Fattachments%2F519%2F519860-87df600b31ab7330414d1ffa506f3cb6.jpg&hash=5e9bca4609b4197e1ca2aaedf3f5ad2f)
![](/proxy.php?image=https%3A%2F%2Fexpeditionportal.com%2Fforum%2Fdata%2Fattachments%2F519%2F519861-bbe1fcef9010eb2d92042d4daff7fd4d.jpg&hash=eb796b59945db4b4c3ab483aa6675230)
![](/proxy.php?image=https%3A%2F%2Fexpeditionportal.com%2Fforum%2Fdata%2Fattachments%2F519%2F519862-19c30d4043df53b7abdbee7810574f89.jpg&hash=3478a01f6f4a2d82a206a582c191d204)
![](/proxy.php?image=https%3A%2F%2Fexpeditionportal.com%2Fforum%2Fdata%2Fattachments%2F519%2F519863-39c6e10710a1533488da98b0b22d06d4.jpg&hash=1ca6bf46fc4810a9103c74c54999c2a2)
![](/proxy.php?image=https%3A%2F%2Fexpeditionportal.com%2Fforum%2Fdata%2Fattachments%2F519%2F519865-363516c6738c32c911cfa9501f499d23.jpg&hash=9de1273d4791250ad992adc2fa76cf19)
1979 Grandby Four wheel camper COMPLETELY REBUILT!:
Pros/Upgrades:
- 156,704 miles 7.3 Powerstroke run with Rotella
- lariat package with complete interior detail completed (heated front seats, full leather)
- Custom center console with built-in safe. Entire console can easily be removed and a replacement center seat could be installed.
- Limited slip rear diff. This truck has the heavier duty dana 80 SRW axle
- engine heater, all weather floor mats, rain deflectors,
- Ravelco antitheft system with two keys. Two remotes and two ignition keys
- Jimmy jammers for all four doors, not yet installed (these prevent someone using a screwdriver to easily open the door.) These take about 20 minutes per door to install.
- Aftermarket radio kit, the radio is just an inexpensive boss radio but the dash panel and radio adapter allow you to put an aftermarket radio in.
- 2 inch front leveling kit
- 285/75R-16 Les shwab Open country tires with about 50%~ tread
- Sinister diesel coolant filter installed at 40,000 miles and run with caterpillar filters
- 40,000 miles to 120,000 miles ran a sinister diesel bypass oil filter. The filter mounting bracket cracked so it is not currently installed but could be reinstalled with a new bracket
- From 40,000 miles to current have run a 6637 air filter
- Tough country winch bumper
- Warn 12,000lbs winch with synthetic line
- Line-X’ed bed
- Hell roaring battery isolator
- Two brand new batteries from Costco
- Jumper cables with quick connect
- Headlights were upgraded by previous owner with a high output harness
- Brand new riffraff diesel silicone boots throughout (intercooler boots not installed yet)
- Brand new alternator
- Upgraded mirrors to 2008 style, power, heated
- Airlift springs with bluetooth remote and compressor
- Rebuilt HPOP in 2019
- Etc.
- Replace all eight glow plugs
- New UVC harness and valve cover gaskets
- Replace injector number three and eight
- New front brake rotors and pads new driver side caliper
- New poly bushings installed on leaf springs, swaybar bushings, rear sway bar bushing’s
- New coolant reservoir/de gas bottle
- Flush coolant system and put in new fleet charge coolant
- New Bilstein shocks on all four corners
- Full Transmission service
- New drag link and tie rod ends/new steering stabilizer
- New upper and lower ball joints
- New vacuum switch (the dash 4 x 4 switch works excellent)
- Rebuilt rear differential with royal purple gear oil
- New rear brakes and rotors/new calipers
- New U joints on driveshaft
- Over $12,000 of work done last year alone to make the truck completely reliable. Have all receipts for work.
- Pull out king size bed
- fits on 2001-2020 Ford or other 8' bed
- All new custom cushions with new foam; three-piece sleeping foam has 1 inch memory foam on top of firm. Vinyl on bottom of cushion prevents condensation damage and allows use on the ground outside.
- Roll over couch converts bottom to full size bed
- All marine grade wiring with AGM battery, 100W solar with MPPT controller
- 20 gallon water tank
- 6 gallon propane water heater
- Ambassador marine grade sink faucet/shower; can be hung outside for exterior shower
- Truck fridge 12v
- Entire camper insulated with 1 inch foam
- All windows upgraded to HEHR
- Fantastic fan
- RV screeded escape hatch installed above upper bed allows access to roof and stargazing
- New rigid insulation and headliner
- All new LED lighting fixtures including red LED nightlight and motion sensing porch light with two side porch lights triggered by the rear porch light.
- 2019; entire camper resided with Dicor (aluminum-solid plastic interior-aluminum). Siding was attached using marine grade 3M adhesive caulk and SS rivets making the entire camper much stronger but still flexible.
- USFS Axe/shovel mount with lock.
- Maxfan rain cover over fantastic fan.
- Roof, hatches, and screws sealed with 3M marine grade caulk.
- Four hydraulic Rico Jacks included
- The relays used for the high output headlight harness work but if they need to be replaced they are expensive Honda relays
- There’s a bunch of miscellaneous wiring from the original camper my neighbors used under the dash. Some of this wiring is for a camera that was linked to a separate monitor in the cab. All of the wire could easily be removed but I left it in place you can fuse any would-be thieves trying to get past the Ravelco system. I’m happy to go over all the wiring with the new owner.
- No center seat; I built a custom console and the old seat got damaged by rodents in storage.
- A few dents and miscellaneous scratches on the truck
- The tough country bumper had some rust spots that I ground out and treated with rust converter. All of the rust was limited to the surface.
- When I took the truck in to get the bed line-X’ed the company that did the work actually put Linux over the camper package in the bed of the truck; basically the front bumper pads and the four camper centering angles our line-Xed in place. Additionally, there are a couple areas where the line X has bubbled, this is covered under warranty and they can re-spray the truck at no charge. If the camper package was removed in advance then the truck bed could be re sprayed under warranty. The camper package really helps to secure the camper and I have never had an issue hauling materials with it in as you can still carry 4 foot wide sheets of material.
- I have not hooked up the wiring from the heated mirrors to the switch in the center console yet, simple job and I may get to it before the sale.
- There's a small tear in the front driver seat approximately an inch and a half to 2 inches long.
- The support board on the camper on the overhang has water damage in the corner and should be replaced. It is totally fine and more of an aesthetic which is why I had it low on the priority list.
- The roof on the camper, as with most of these campers, has some hail damage and is a little bit dinged up.
- The front camper roof lift support has some minor water damage. I have another lift panel. that is in new condition but not installed.
- There are probably a few more very minor things, but at the moment I honestly can't think of them.
