Dirt Clod
Lightweight pop up camper similar to a four wheel camper or an all terrain camper. It’s designed for a full size truck and will fit perfectly on an 8’ bed or hang over on to the tailgate on a shorter length bed.
It has a full/queen sized bed in the cab over and you can also rearrange the dinette into another twin+ sized bed. It will sleep 3 adults.
It’s wired for electrical, has a forced air furnace that runs on propane, a sink with a small water tank and a spot for a porta potti.
It has a small Grey water tank and could be considered a fully self contained camper if you use a porta potti allowing camping in spots like on the beach in Ventura.
It also has a small 50watt solar panel and an area inside that Was used for a cooler or portable cooler style top loading refrigerator.
This is an older camper from the early 90s thus it will NOT fit most trucks made after around 1997.
It should fit OBS fords up to 1997 and gmc/chevys up to 1998.
Please review the sizing sketch and measure your bed to verify fit before you contact me. This is really all the info you should need to verify if it will fit your bed without modifications.
PLEASE MEASURE YOUR BED AND VERIFY IT WILL FIT!!!
It’s in good shape and has had tons of work over the years (including almost all new GFRC siding) but the plastic windows were shot as well as the screens so they were removed. The thread on the Velcro holding in the windows was deteriorated and tore off. I have new plastic that I will include in the sale.
I also have the pvc coated fabric that I will include if you want to redo the tent material.
It currently has only big openings where the windows were in the tent. You could use it as it is too. It’s nice to have the ventilation in the summer.
This is a very cool and rare old camper.
It’s Is a bit of a project to fix the windows or redo the tent but that would really take it to the next level.
I'm located in Los Angeles....
Asking only $1400 and that includes the jacks...
Thanks and happy camping.
![001.jpg 001.jpg](https://www.wanderthewest.com/data/attachments/30/30095-b9f472fc527c90deccc2078691564190.jpg)
![003.jpg 003.jpg](https://www.wanderthewest.com/data/attachments/30/30096-8cdbe2695a5f7916b87bfcd764373a5a.jpg)
![004.jpg 004.jpg](https://www.wanderthewest.com/data/attachments/30/30097-b7b9d374628524f80984db6115fe5871.jpg)
![005.jpg 005.jpg](https://www.wanderthewest.com/data/attachments/30/30098-978951270b39aac1f57c967d82f157b5.jpg)
![007.jpg 007.jpg](https://www.wanderthewest.com/data/attachments/30/30099-7c55d0270c5f771c94223f3e2c2f8080.jpg)
![011.jpg 011.jpg](https://www.wanderthewest.com/data/attachments/30/30101-40642a1d463d3a46092b108db687b790.jpg)
