Jack
We moved our Fleet onto a Ford Ranger from our 2005 Tacoma and are selling the mounting bars and pads for $25
Not included is the forward pad and a slice of the rear mat (they got repurposed for the Ranger). The mats will work as is, but you may want find similar mats at Home Depot or horse floor pads at a tack shop for complete coverage.
The bars are the 2005 - 2017 style - without the centering bevels. I used 2x2 trimmed down and slid them along the sides to center the back end of the Fleet when loading it onto the Tacoma.
You will need a heavy duty pneumatic wrench to loosen the bed bolts in your Tacoma - or have s shop loosen them for you and then tighten them afterwards.
To complete the mounting, you will need an Attwood 7648-7 socket, a 30 A self resetting circuit breaker and a length of 10 gauge exterior wire. Instead of mounting the socket in the wall of the truck bed, I ran the wire of the top front of the bed and under the chassis plastic tied it underneath the chassis. A lot easier to get when loading and unloading. The socket and circuit breaker are available on Amazon:
https://www.amazon.com/attwood-Connector-Trolling-Motor-Female/dp/B001O0D6O2/ref=sr_1_1?dchild=1&keywords=attwood+7648-7&qid=1590020106&sr=8-1
https://www.amazon.com/Fastronix-Automatic-Reset-Circuit-Breaker/dp/B07NSD3KYH/ref=sr_1_18_sspa?crid=2QOMZXXWMQHRH&dchild=1&keywords=30a%2Bself%2Bresetting%2Bfuse&qid=1590018556&sprefix=30%2Ba%2Bself%2Bresetting%2Caps%2C211&sr=8-18-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExUktZVURETlJTNEVVJmVuY3J5cHRlZElkPUEwNzc0NDAzMVpJQ1o2T1NQMzM5TCZlbmNyeXB0ZWRBZElkPUEwNTI0NTY1SjlYWkhBWkdXQzYmd2lkZ2V0TmFtZT1zcF9tdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl&th=1
If you can figure out how to ship and cover the cost, I'll do my part.
Most dealers will want to install the factory kit, but if you mount the bars, they may cut you a deal. If you do the full mounting setup, most dealers will just slide it on.
